Kioti K9 Parts
/ Kioti K9 Parts
Just used you Wix link and am going to give Wix 51381 a try.
P.S. I have a DK35 I purchased back 2005. Back then the DK series was bigger line of Kioti tractors. Seems like they had a renaming of their tractor lines since then. Anyway my DK35 has been a flawless performer for me and I ran it hard mowing steep fields of high grass, weeds and sometimes trees. Yikes! All the while pulling a 6' brush hog. If I could push it down the Kioti would cut it off. What a beast!
Thanks for the help.
/ Kioti K9 Parts #7
Generally if you take off the first Wix number you have a Napa number.
Should be a Napa 1381
My 2001 DK 35 also calls for the Napa 1381
/ Kioti K9 Parts #8
I've had the same luck with my DK 35 since 2001.
It's been an excellent tractor
/ Kioti K9 Parts
Vince,
They are telling me I need oil filter E5205-32091. Does that make sense to you?
Thanks
/ Kioti K9 Parts
Looks like the Wix number you provided will work. I ordered one to give a try.
Thanks a bunch for your help.
/ Kioti K9 Parts
I ended up purchasing Purolator Pure One PN: PL 14459. Fit perfectly on my Kioti K9 using your Wix part number 51334 as the cross reference number at Advanced Auto Parts.
Thank you so much. No wonder you are rated so high (Super Member) on this site.
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
John Deere S350 (A60462)
John Deere S350...
2015 Nissan Quest Van (A61569)
2015 Nissan Quest...
2016 Ford F-550 4x4 Mason Dump Truck (A61568)
2016 Ford F-550...
2002 John Deere 4510 Tractor (A64047)
2002 John Deere...
New/Unused SD Lanch SDLGC100 6-Seater Electric Golf Cart (A61166)
New/Unused SD...
