Kioti DK45S Engine Side Panels
/ Kioti DK45S Engine Side Panels #1
Harley65
SOSO, MS
2006 Kioti DK45S
I have a 2006 DK45S. The right engine compartment panel fell off the tractor while using my rotary cutter. I managed to stop before it became minced junk but the rear wheel clipped the front corner and bent one of the clips that hold it in place to a 1/4" post on the frame. I called the dealer and they said the parts catalogue doesn't show it separate. Does anyone know where I can find a replacement clip, there are two on each side (front and rear). I really don't want to pay $200 bucks for a new panel because the clip broke.
/ Kioti DK45S Engine Side Panels #2
I don't see it in the parts breakout either. Maybe it's something Kioti can supply by special request but a dealer would probably need to ask for it. Maybe a local metal shop can make a copy of the unbent clip from the other side? In the meantime I don't see a problem running without the side panel.
Thanks for your suggestion and I have been leaving them off. The problem is we have a lot of thick privy or progressive hedges in MS and their limbs invade the engine compartment while cutting. I recently replaced the 'plastic' fan blade because of that, needless to say I don't need that experience again. Thinking about using a plastic cable tie to hold it in place until I can find a clip. Anyway, I can't be the first to brake one of these clips.
/ Kioti DK45S Engine Side Panels #4
The PO of my tractor bent the living bejeezus out of the LH side cover. I had the choice of buying new at about $350 or straightening out the twisted wreckage. If you can't yourself, maybe a body shop can help you. They can probably fab some clips if need be. I was able to get mine pretty close to original. At least it stays in place. It will never be pretty.
Thanks o2batsea, I was able to reengineer the mess by moving the front clip to back position. After I applied a couple wraps of electrical tape to the middle of the 'bar' I removed from the rear (both tangs broke off trying to straighten them) I mounted it on top of the spacers in the front. Then placed two large plastic ties partially cinched around the bar. After positioning the rear pin and clip, I looped the ties around the front 1/4" pin and pulled the ties tight. It is just a field repair but it seems to work nicely. If anyone finds a part number for these clips please let me know. Thanks
(2) Tractor Wheel Weights (A65640)
(2) Tractor Wheel...
KUBOTA SVL97-2 (A65643)
KUBOTA SVL97-2...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A65054)
(INOP)1989 NISSAN...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
Walnut Picnic Table (A66408)
Walnut Picnic...
10ft. Barge Box Wagon with Hoist (A65640)
10ft. Barge Box...
