Kioti DK40se Hydrostatic backups when in gear
/ Kioti DK40se Hydrostatic backups when in gear #1
cartrydge
lillington, nc
kioti
So after my tractor seems to be stuck going backwards. You have to press the hydrostaic forward pedal in a little to actually get it to change gears and once you take foot off pedals it backups on it's own. I tried to adjust the pedals under the tractor but, that just moves them up and down didn't fix the issue. Anyone know how to adjust this?
Thanks,
/ Kioti DK40se Hydrostatic backups when in gear #2
Welcome from Ohio, You under warranty at all?
/ Kioti DK40se Hydrostatic backups when in gear #3
The hydro petal adjustments are very specific. PM me for a PDF of the measurements. Also, it sounds like something might be binding, have you lubed everything and made sure nothing has jammed up in the length of linkage like a stick?
Yea it only has 38 hours on it so it's still under warranty. I was hoping it was a quick fix though cause the dealer is over an hour away and I don't have a trailer capable of moving it.
