Kioti DK40se Hydrostatic backups when in gear
   / Kioti DK40se Hydrostatic backups when in gear #1
cartrydge
lillington, nc
kioti
So after my tractor seems to be stuck going backwards. You have to press the hydrostaic forward pedal in a little to actually get it to change gears and once you take foot off pedals it backups on it's own. I tried to adjust the pedals under the tractor but, that just moves them up and down didn't fix the issue. Anyone know how to adjust this?
Thanks,
   / Kioti DK40se Hydrostatic backups when in gear #2
Welcome from Ohio, You under warranty at all?
   / Kioti DK40se Hydrostatic backups when in gear #3
The hydro petal adjustments are very specific. PM me for a PDF of the measurements. Also, it sounds like something might be binding, have you lubed everything and made sure nothing has jammed up in the length of linkage like a stick?
Yea it only has 38 hours on it so it's still under warranty. I was hoping it was a quick fix though cause the dealer is over an hour away and I don't have a trailer capable of moving it.
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2017 John Deere 1025R Tractor - 626 Engine Hours (A55315)
2017 John Deere...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56435)
2023 Kubota...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
