beckmurph
Platinum Member
If, you foresee switching the backhoe often, check out how easy it is to hook and unhook each backhoe.
that right there would have me buying the mahindra or an LS or...... IMO do what you are doing and research the heck out of it then find a dealer and sit / operate the tractor, talk to the service department, ask for referrals. If they balk at any of that just walk away. the only point of a dealer is to provide service before and after the sale, if they are failing to provide the service before you give them your money do you really expect it to get better after? It never hurts to let them know you are shopping several vendors and that you have done a lot of research.I feel the front end loader specs are quite a bit different, roughly 25% more lift to a higher position is significant, in my opinion. I plan to use pallets to store and move several things in my barn.
I agree that the BH of the kubota seems better than the Kioti and Mahindra. Neither Kioti nor Kubota dealers near me will let me drive them without a deposit put down; but the Kioti seems most similar to what I have used in the past; and as such more familiar.
You arent lifting pallets of stone with any of these machines. , logs yes but you may need to cut them down so they dont weight 1000 lbs, etc. animal feed can get heavy if you are talking pallets. Brush hogging, provided you dont have hills and tall grass 25HP should work ok. You might need to take the FEL off if you feel power is lacking.It will be general property maintenance, and down the road used to help establish a new homestead. Moving logs, dirt and gravel work, pallets of stones, brush hogging, digging water/sewer/electrical trenches. Moving animal feed/hay.
I feel mostly the same about the dealers, Kubota dealer has been around longer, but seems less well kept up. Both are busy, but both were helpful as well and seem to stock filters/fluids, etc.
Yes, thats ridiculous. I would tell them they can either let you on it (maybe signa waiver) or you will go elsewhere.that right there would have me buying the mahindra or an LS or...... IMO do what you are doing and research the heck out of it then find a dealer and sit / operate the tractor, talk to the service department, ask for referrals. If they balk at any of that just walk away. the only point of a dealer is to provide service before and after the sale, if they are failing to provide the service before you give them your money do you really expect it to get better after? It never hurts to let them know you are shopping several vendors and that you have done a lot of research.
I almost bought a used 2615 (about the same as the 1626) and i liked it a lot, a very capable machine for the weight.Their are lots of you tube vids on people with mahindra 1626s out there, Most seem to really like them, I have two mahindras 1600 hrs total on both . They are good machines.
I'm on my 2nd Kioti, traded the first after 7 years and 550 hours for a bigger unit, CS2410 subcompact to a CX2510 compact. I've been very very happy with Kioti. Other then a hydraulic line on the smaller tractor I've simply never had an issue with either.Hi all,
I am currently cross shopping all of these with a loader and backhoe, and I am somewhat at a loss of which direction to go.
Kioti - 23K for tractor Loader plus roughly 9K for backhoe - 32K total. Currently in Stock locally. Seems to be the most capable front end loader.
Mahindra - 29K for Tractor/loader/backhoe plus a free box blade and pallet forks with their current incentives. Seems to be the least reviewed of the three, but definitely the most affordable. Currently not in stock locally, but they are on order.
Kubota - 23K for tractor, plus roughly 10K for the backhoe. 33K total. Most expensive, lowest front end loader specs, possibly the best resale? Currently in stock locally
All three seem very comparable, all three are right near the top of my price range. Currently leaning towards the Kioti, for the front end loader capacity; but looking for any opinions.
Thank You
It wasnt nothing malicious against kioti.You've conveniently rounded the Kioti numbers down and the Kubota numbers up.
The LA525 loader lifts:
1,082 lbs to max height of 94.3"
1,431 lbs at 1500 mm height
The KL 4030 loader lifts:
[not specified] to a lift height of 98.4 in (4.1" higher than the Kubota)
1,835 lbs at 1520 mm height.
That's a 434 lb difference, not the 300 lb difference you stated.
Or, think of it as the Kioti lifts 28% more than the Kubota! That is quite significant.
