KIOTI CK2610 fluid advice
/ KIOTI CK2610 fluid advice #61
"Religion, politics, and oil weight/brand.
Those are the things you should never talk about with anyone but your very closest friends. As it always leads to a fight."
Don't forget welder brands.... any of that discussion garrantees a hate crime within 5 replies!
With that being said, I have to respectfully disagree about switching motor oil brands. Thats an old wives tale. Just like switching from dino to synthetic or vice versa shouldn't be done. Unless its an old school engine without an oil filter, pick the right weight for your climate (see the manual) and buy any quality brand. You'll never go wrong. (And if the manual says use full synthetic, do that too.)
Now if you were talking about hydraulic fluid, I retract my statement as my knowledge there is limited.
I'm In South Western PA, so pretty neutral climate, no major winters or scorching hot summers.. After looking at the API rating and temperature charts, I think I'm good. Only confusion is the manual I have says "Engine Oil: tier 2 or 3 - API CH grade or above Tier 4 API CJ grade above. Oil Viscosity: SAE 10W30, 10W40, 15W40."
Not too sure what tier I fall into but I figured the Rotella T5 is API rated for API CK-4, CJ-4, CI-4 or CH-4
/ KIOTI CK2610 fluid advice #63
Well, I watch very little You Tube, but "The Motor Oil Geek" sure seems to have more than enough credentials and knows what he's talking about.
If he recommends against it, that's good enough for me. And I'd guess that mixing them mattered much less in the old wives tales days, when the oils were far less specialized and with fewer additives.
/ KIOTI CK2610 fluid advice #64
But the little bit of oil left over after an oil change is fine.
What he's mostly against is using additives or mixing different brands, or versions in the the same brands, in whole amounts. Like mixing in 2 quarts of High Mileage with the rest being Long Life. They have two completely different additive packages.
/ KIOTI CK2610 fluid advice #65
Not all engines drain as completely as others, so the results can vary.
I just can't see switching brands unless it's necessary for some reason.
/ KIOTI CK2610 fluid advice #66
Except for my '93 Corvette I've never had any idea what oil the manufacturer loaded into the vehicle ('93 had Mobile1 stickers on it). So basically the OEMs completely negate your argument. They want you to use a specific API minimum and then certain weights, based upon climate and tractoring style.
Besides, say you are married to Delvac, which is now at CK-4. What do you do when Delvac switches to CL-4? It's a different additive package, maybe not from even the same additive maker.
/ KIOTI CK2610 fluid advice #67
Some of you folks would shun me. My truck has a mix of Castrol 5W-20, 0W-20, and Mobil 5W-20 in it now. My new wood chipper got a mix of Walmart and Quaker State 5W-30 when it specs 10W-30, I forgot what is in my splitter, snow blower, and generator. I have 19 gallons from 4 different companies of bar and chain oil on hand, and I have two brands of 2 stroke oil.🙃
/ KIOTI CK2610 fluid advice #68
Wonder what they would think of my off brand ATF and diesel blend for cutting oil? Couldn't possibly work, it's not UL listed as approved cutting fluid
/ KIOTI CK2610 fluid advice #69
I have used the same for cutting fluid for many years, that said.
For motor oil in my tractors they all have 5W-40 synethic and have for years.
For "hytran" fluids most of mine is and has been Cen-Pe-Co multi purpose fluid. It is a blended para synthetic.
/ KIOTI CK2610 fluid advice #70
That first oil change, which I generally do at about 500 miles, can indeed be a switch of brands if the manufacturer and/or dealer refuses to let you know what oil the factory fill is.
Thankfully I know what most vehicles came with, and if I later use an oil that's different from the factory fill it's only that first oil change that will differ.
What I have done when the specs change, like from CK-4to CL-4, is check if the fluids are backwards compatible. So far they have been.
/ KIOTI CK2610 fluid advice #71
It doesn't make a bit of difference if you change brands of oil, as long as it is a quality lubricate your engine will be fine. I have never worried about what brand a manufacture put in an engine.
/ KIOTI CK2610 fluid advice #72
I don't worry about it either, but try not to change brands unless I have to.
Of course, in some cases there's only one approved brand and grade to choose from, and they claim that using anything else will void the warranty. Plus, it has to be changed every six months, even if the vehicle hasn't been driven.
/ KIOTI CK2610 fluid advice #73
That's illegal in the US and most countries as far as I know.
/ KIOTI CK2610 fluid advice #74
Illegal or not, when the manufacturer specifies MS-12633 and there's only one oil meets that spec, there's not much choice.
Although, it looks like people have found at least one other oil that meets that spec, and I think the manufacturer recently added another approved spec.
/ KIOTI CK2610 fluid advice #75
Try MS-A0921 and there’s not only one oil that meets the spec. There is and probably always will be BS passed by the interwebz.
/ KIOTI CK2610 fluid advice #76
Sorry, didn't remember the number of the new spec, but yes, it's MS-A0921.
Anyway, out of curiosity, what is the BS? I've been keeping up on the MS-12633 for a few years, but am not fanatical about the subject so there's likely something I've missed.
/ KIOTI CK2610 fluid advice #77
In case anybody decides to install remotes (CKA111) on a Kioti, this one photo might be more helpful than the absolutely miserable instructions.
Okay, easy for me to say, perhaps, since I just finished the task.
/ KIOTI CK2610 fluid advice #78
While messing with this Kioti I also installed a switch on the base of the seat to avoid having the engine stop whenever I get off the seat.
In Off position the seat nanny works as intended, but when turned to On I can lock in the Quick Tach levers and do other things without going through the whole Neutral, parking brake on, routine.
/ KIOTI CK2610 fluid advice #79
My dealer gave me a little plug to defeat that stuff, but that's a nice clean install right there. Also safer if it were to roll and you get tossed from the seat.
/ KIOTI CK2610 fluid advice #80
@ODZD did you do fuel filter? It seems stupid, but when I check manual, there are distinctly two different models, depending on if a "B" or "F" model? I have a CK2610H. Is that a "B" or an "F"
HYD BREAKER HAMMER (A60429)
HYD BREAKER HAMMER...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A59231)
2009 Mariah SC23...
2013 HAM 289I-30 8 WHEEL PNEUMATIC ROLLER (A60429)
2013 HAM 289I-30 8...
2018 Yamaha VX1050B-TA Waverunner Jet Ski (A59231)
2018 Yamaha...
2018 JOHN DEERE 323E SKID STEER (A60429)
2018 JOHN DEERE...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2017 Ford F-150...
