KIOTI CK2610 fluid advice
   / KIOTI CK2610 fluid advice
Thanks everyone! I got filters coming in tomorrow and I'll be picking up the following:
SAE 15W-40 Rotella T5 - Engine Oil
Mobil 424 Hydraulic Fluid - Hydraulic system
SAE 80W-90 Gear Oil - Front Axle
3-4 tubes of Red n Tacky for greasing the loader.
Anything else I'm missing?
   / KIOTI CK2610 fluid advice #22
A drain pan that holds atleast 5 gallons; and you will Need a flex neck funnel.
   / KIOTI CK2610 fluid advice #23
The only things I would add (and it has been mentioned by others here) is to check the dipstick levels on the fluids before changing and if they are in the correct range measure what you take out (including draining the filters) and replace with the same amount (with a few extra mls for the new dry filter material.
It will get you closer to where you want to be in the end.
The front axles in particular need to have the wheels rotated to distribute the new fluid to all the nooks and crannies. Jack the front axle so you can spin the wheels manually and/or drive and recheck the levels.
Also check the manual for your model whether the measuring dipstick is correctly read fully screwed in or just put into the hole to the first thread.
There is a learning curve the first time for everything. Rechecking your dip sticks a few times over the first 1-2 working hours will give you the confidence you did it correctly.
   / KIOTI CK2610 fluid advice #25
Poked around a bit today looking for HST oil, and that 424 was available at several places.
No luck around here. 2 auto zones and a Napa. Maybe those aren’t the best places to look?
   / KIOTI CK2610 fluid advice #29
The Delvac can be found at Walmart in 2.5 gallon jugs. $42.98.
   / KIOTI CK2610 fluid advice #30
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
New Holland C345 (A50120)
New Holland C345...
Bad Boy Zero Turn **Does Not Run** (A50121)
Bad Boy Zero Turn...
3001 (A51691)
3001 (A51691)
Club Car (A50121)
Club Car (A50121)
