Kioti CK20 Won't start after doing something by accident, help?
   / Kioti CK20 Won't start after doing something by accident, help? #11
I don't know anything about Kioti tractors, but I know a lot about dead batteries. I have had many. It sounds like you are not getting any current, anywhere. (No lights, etc.). Put a voltmeter on the battery and see if it is charged (about 12.5 volts). If it is, check the cables and battery terminal clamps. Sounds like you have a bad connection, somewhere.
I have another thread on another section of the forum, and I believe I have found the issue to be a 60 amp fuse that is next to the starter, It appears to be bad, so I have the new part coming hopefully tonight and I will keep everybody posted! Thanks so much for the help!
   / Kioti CK20 Won't start after doing something by accident, help? #13
I read earlier that the red wire melted onto the muffler, that's a direct short probably where the blown fuse came from..
   / Kioti CK20 Won't start after doing something by accident, help? #14
I found the starter, and I hooked the red wire from my jeep battery directly to the starter, and it still didn't give any power or turn over.
Didnt hook up the neg to the jeep?
   / Kioti CK20 Won't start after doing something by accident, help? #15
I believe on his other thread, he replaced the fuse and that fixed the problem.. I suspect the wire coming in contact with the hot muffler was the initial cause.
   / Kioti CK20 Won't start after doing something by accident, help? #16
When you say "filled it with gas" (twice), you did mean diesel fuel, correct?
I'm with you. I was sitting saying to myself, "well there's your problem right there!"
   / Kioti CK20 Won't start after doing something by accident, help? #17
Yes, but if he had, the starter would've turned :)
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
Sundowner Rancher Express 20FT Livestock Trailer (A56435)
Sundowner Rancher...
(UNUSED) WESTERNDORF 4200 BRUSH CRUSHER GRAPPLE (A52708)
(UNUSED)...
Jacobsen three wheeler mower (A56857)
Jacobsen three...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
