Kioti CK20 Won't start after doing something by accident, help?
   / Kioti CK20 Won't start after doing something by accident, help? #11
I don't know anything about Kioti tractors, but I know a lot about dead batteries. I have had many. It sounds like you are not getting any current, anywhere. (No lights, etc.). Put a voltmeter on the battery and see if it is charged (about 12.5 volts). If it is, check the cables and battery terminal clamps. Sounds like you have a bad connection, somewhere.
I have another thread on another section of the forum, and I believe I have found the issue to be a 60 amp fuse that is next to the starter, It appears to be bad, so I have the new part coming hopefully tonight and I will keep everybody posted! Thanks so much for the help!
   / Kioti CK20 Won't start after doing something by accident, help? #13
I read earlier that the red wire melted onto the muffler, that's a direct short probably where the blown fuse came from..
   / Kioti CK20 Won't start after doing something by accident, help? #14
I found the starter, and I hooked the red wire from my jeep battery directly to the starter, and it still didn't give any power or turn over.
Didnt hook up the neg to the jeep?
   / Kioti CK20 Won't start after doing something by accident, help? #15
I believe on his other thread, he replaced the fuse and that fixed the problem.. I suspect the wire coming in contact with the hot muffler was the initial cause.
   / Kioti CK20 Won't start after doing something by accident, help? #16
When you say "filled it with gas" (twice), you did mean diesel fuel, correct?
I'm with you. I was sitting saying to myself, "well there's your problem right there!"
   / Kioti CK20 Won't start after doing something by accident, help? #17
Yes, but if he had, the starter would've turned :)
2021 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2021 Ford F-250...
2019 DODGE RAM LARAMIE 5500 FLATBED (A58214)
2019 DODGE RAM...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A55973)
2006 Crimson...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
