Kioti CK20 HST
   / Kioti CK20 HST #1
Drivenhard
2003 Kioti CK20HST
Kioti CK20 HST
RE: Transmission Pump/Motor Plates.
Can someone tell me which is the Pump plate? Both look the same except one has 2 fluid passages and the other has 4
Any help would be appreciated
Rick
   / Kioti CK20 HST #2
Did you try michiganiron site. Look up parts diagram. Than try and get photo of both parts.
   / Kioti CK20 HST
I purchased the same service exploded view/parts list manual as what they have on their parts finder. I also bought a service manual and neither one give the identification or orientation of the valve plates. I did text, emailed Michigan Iron and waiting for a reply. This tractor has so many serial number part breaks that when you order one part, you have to order another part to make it work. Then order another to make the second part work. I’m replacing the main shaft, pump shaft, main coupler, bearings, prongs, e and c clips in the transmission this time around. Previously I have rebuilt/replaced the front differential, clutch pressure plate/disc (2), glow plugs, multiple relays to name a few.
Thanks for your reply, appreciated.
   / Kioti CK20 HST #4
Theres a place called Jordan sales and service here in north idaho. They have always been helpful to me in identifying parts and answering questions. They have a very large dealership and repair facility
1-208-777-0743. Maybe give them a call.
   / Kioti CK20 HST #5
I looked at parts breakdown that I have for Rexroth hydrostatic pump and motor. it showed having two fishtails per side on the port plate for the pump and one per side on the motor.
I am not positive Kioti is the same design though.
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
2022 John Deere R4023 (A60462)
2022 John Deere...
2024 CATERPILLAR 306CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2017 Ford F-650 Service Truck (A59230)
2017 Ford F-650...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
