Kioti CK20 Engine Problem
/ Kioti CK20 Engine Problem #1
Makatak
E2303
I have a 2006 ck20 that I bought not running. I am a fairly decent mechanic but I am stumped. The guy I bought it from said it had been setting up because of a problem. He said the “cam” for the injector pump had been replaced and it was not “timed” correctly. I motored it over after putting new diesel in it. i bled each of the injector lines from the pump to the injectors until I was getting “squirts” of diesel from each one then tightened them down. I expected it to try to run, but got nothing. Compression is good on all 3 cylinders. I tried looking up how to time the injector pump with the position of the gears and the flywheel but couldn’t find anything on line. Any help would be appreciated..
/ Kioti CK20 Engine Problem #2
there was a batch of fuel pumps that sheared the timing gears in the ck series, there is a bit of stuff about it,
/ Kioti CK20 Engine Problem #3
And it was the 2005-2008 model years.
1988 Ford Mustang GT Convertible (A61574)
1988 Ford Mustang...
2017 Ford F-250 Ext Cab Pickup Truck (A61573)
2017 Ford F-250...
(2) CATTLE SHUTE RAILS (A64280)
(2) CATTLE SHUTE...
ROLLS OF CHAIN LINK FENCE (A64281)
ROLLS OF CHAIN...
UNUSED X-STAR 101"x20' LOADING RAMP (A64280)
UNUSED X-STAR...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
