Kioti Broken in Half
   / Kioti Broken in Half #201
When I design the base to install an electric 12K lbs.winch between my hood and front bumper, (moving it a few inches), I leave enough clearance (1/2") to raise and lower the FEL, but I also design to weld a 4" x 20" x 3/4" reinforcement plate under the tractor frame, just in case to avoid this kind of fractures.
By the way, I'm not planning to use the winch full force at the front like I will when it"s installed at the draw bar to pull tree trunks.
   / Kioti Broken in Half #203
That's not very informed...Tractors ARE made to have loaders...They have been on them from day 1. One of the most popular attachments ever used on a farm or CUT. Maybe you better research the use of loaders on tractors. Of course any tractor can and will break in half if abused. I have seen at least six tractors that have either broken at the bell housing or the front axle mounting area...Bell housing being the more common among certain brands....in fact many tractors NEVER had a frame at all. NONE.
NOT from day 1, not even year 1.
It was several years before loader debuted on farm tractors.
   / Kioti Broken in Half #204
which literally means nothing, vehicles didn't have air conditioning when they first came out, then they were DESIGNED to have it.
If it comes from the dealer with a loader with the name of the tractor on it, its designed for it. do they bolt in? or have to be welded/ drilled in? they bolt in, thus designed for it. no different then installing a hitch on a vehicle that gets bolted in, why do you think the holes are there? because they are designed to be for a hitch.
I can't remotely believe this is even a question. If a dealer sells an attachment straight out of their factory book, then its obviously designed for it, how is this any different, then a radio made by DENSO in a car? because its not made directly by chevy/gm etc, then its not designed for it? this thought process is ridiculous.
   / Kioti Broken in Half #205
What
Then that sure as HECK isn't from day 1 is IT......
   / Kioti Broken in Half #206
What
I personally don't see why that is even relevant? your saying rev1 of any product is always best? pretty sure that's the direct opposite of reality
   / Kioti Broken in Half #207
My answer was to post #197, your answer is what is not relevant.
   / Kioti Broken in Half #208
I've been pulling saplings and grappling for years and have yet to get the front wheels off the ground when using either attachment. I suppose there will be a first time though, just not yet.
   / Kioti Broken in Half #209
Tractors are designed to do what they are meant to do under normal parameters but people don't always judge how some changes could affect the tractors performance and I'm not only talking about the oversized attachment.
What I saw in a picture it's a tractor that was operating on wet soil full of slippery rocks covered by leaves (more slippery) on an uneven terrain probably doing something that it is not supposed to do on such particular circumstance, who knows at what speed and what kind of maneuvers to break the already fatigued frame (?)
Is the operator qualified ?
He was overconfident and caused the accident that shouldn't have happened in the first place because he was not operating under normal parameters.
I can't judge the tractor because I know now that it probably was abused.
   / Kioti Broken in Half #210
its not broken, just articulating in the wrong direction. A new feature from The Orange Crush
   / Kioti Broken in Half #211
Working well within the specs and limits of course.....:cool:
   / Kioti Broken in Half #212
   / Kioti Broken in Half #213
Well, the current design of tractors don't really reflect that it's made for heavy lifting at the front.
Then all tractors would have been articulated as it should have been for front loader work.
   / Kioti Broken in Half #214
Valtra has some really cool engineering. That articulating tractor looks almost identical to a typical straight tractor. The few that have them here in the states really like them. Now that they are an AGCO brand, it has helped sales here
   / Kioti Broken in Half #215
How many FEL tractors have you owned? What were the make/models?
   / Kioti Broken in Half #216
For their specific needs Europeans are miles ahead of us in their design.
   / Kioti Broken in Half #217
Here's not something you see every day. Browsing facebook and saw this.
Not sure what the backstory is.
It is not uncommon these days. My neighbor cracked a new 75HP New Holland in half while mowing. He hit a ditch at a nice clip and cracked it just like the picture here. he is very hard on equipment. Smaller tractors have become less structurally sound due to price competitiveness. New Holland, Deere, Kubota etc. have had to cheapen their products over the past twenty years to compete with cheap brands.
   / Kioti Broken in Half #218
Well, to be honest is sold in modest number, today Valtra has this strange construction.
Wrong link
   / Kioti Broken in Half #219
   / Kioti Broken in Half #220
In 1985 I helped a large farmer with his Fall harvest. My job was to do Fall tillage. I ran one of these Case tractors. The tractor had three steering options. It was a rigid frame and got it's turning abilities by independent control of both axles and they both had equal turning capabilities. It was a treat to run.
Here's a video if you've never saw one.
2023 Ford F-150 Crew Cab Pickup Truck (A59230)
2023 Ford F-150...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
KBH Tender (A61307)
KBH Tender (A61307)
