Grading Kioti 60" Rear Blade Question
   / Kioti 60" Rear Blade Question #1
sunnyside360
Central PA
JD 3720, JD 4320, JD 835R, Kubota M4D-071, Kubota ZD1511
Hello. My neighbor just recently purchased a new Kioti CK25HST with FEL and a 60" Kioti rear blade -- very nice tractor. My neighbor has a 3000' gravel driveway and he plows the snow with the rear blade. Does anyone know if skid shoes are available for the blade to prevent it from digging into the road?? (blade is digging into the road when it is not frozen)
   / Kioti 60" Rear Blade Question #2
Which brand is it? Most do not. You can buy the shoes for about $15-$20.00 each and weld some pipe brackets on to the blade as I did and mount them your self. They are washer adjustable.
   / Kioti 60" Rear Blade Question #3
Opps! I should have looked closer at your post. It is a Kioti Blade!
   / Kioti 60" Rear Blade Question #5
KenGod said:
I need to get some feet as well, I couldnt find much, gonna have to break out the welder.
I did find a bolt on pair for $80.00, but not allot of adjustment, Have a look
I bought a pair of skid shoes from Tractor Supply. Fabbed up the brackets from some scrap metal and utilized existing holes in my Kioti 72" blade.
Don
   / Kioti 60" Rear Blade Question #6
The best and cheapest way to go is to do what Don did.
Cut out the middleman.
You can occasionally find them on ebay too.
BTI
   / Kioti 60" Rear Blade Question #7
With or old Ford blade - If you want to plow snow and not dig in I turn the blade 180 deg. Is that possable with the Kioti ?
   / Kioti 60" Rear Blade Question #8
I've used reinforced rubber mat, like conveyor belt material or an old truck bed mat, sandwiched between the blade frame and the removable blade. Works like a squeegee over the dirt and limits the damage.
TomK, this idea is new to me but I think I understand what you mean. How much material did you leave extending beyond/below the bottom edge of the cutting blade?
Highgear, good suggestion. If I remember correctly, the Kioti cutting blade is removable and may be reversible. I will check.
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2000 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2000 Mack CH613...
NEW Woods 6ft Finish Mower (A52748)
NEW Woods 6ft...
2013 Chrysler Town and Country Van (A50324)
2013 Chrysler Town...
Knight 1040 Manure Spreader (A50774)
Knight 1040 Manure...
