Grading Kioti 60" Rear Blade Question
   / Kioti 60" Rear Blade Question #11
I was going to add shoes to my 6' blade that I got at TSC but on the suggestion of another member, I reversed it and shortened the toplink to give it a pretty steep angle on the ground. I use it that way in the summer to smooth my road and and winter for snow. If I want more dig in, I lengthen the toplink to get the blade to stand more upright. Works great.
   / Kioti 60" Rear Blade Question #12
To sunnyside 360 - I didn't mean the cutting edge . I turn the complete blade around and plow with it backwards . Can you not do that with the Kioti blade ? So when I want to clean off cement or black top I turn the blade so it cuts in , and if I want to clean off grass or dirt I pull the pin on the blade and swing it all the way ( 180 deg. ) around .
   / Kioti 60" Rear Blade Question #13
I haven't plowed snow but with my rear Kioti blade I found it to be way more useful with the installation of a tilt cylinder (which needs a single rear remote to operate) The tilt feature built into the blade is in my opinion useless as the first position off centered is about 20 degrees which translates into several inches of tilt. Often a person just needs somewhere between O degrees and maybe an inch or two which is what you can do with the tilt cylinder. Especially useful for those with hilly and varied terrain. I suppose in nebraska it would be useless?
Highgear -- oh, now I understand what you meant. That should definitely keep the blade from cutting into the road. Yes, the blade can be turned 180 degrees. It's certainly worth a try and doesn't cost anything. Thanks.
ERE -- will try this the next time it snows. Best psrt is it doesn't cost a dime. Thanks.
Tractor -- this sounds like a good method if you have a rear hydraulic connection which this CK25 does not have. Thanks
TBDonnelly said:
I bought a pair of skid shoes from Tractor Supply. Fabbed up the brackets from some scrap metal and utilized existing holes in my Kioti 72" blade.
Don
Don, there is a TSC store about 15 miles away, I'll check them out. Thanks
   / Kioti 60" Rear Blade Question #19
My CK30 didnt originally have the rear remote---I added it, they sell a kit. You can buy single or dual.
   / Kioti 60" Rear Blade Question #20
sunnyside360 said:
TomK, this idea is new to me but I think I understand what you mean. How much material did you leave extending beyond/below the bottom edge of the cutting blade?
Sorry it took so long to get back to this. I just leave about 1" to 2" below the blade so it supports the weight of the blade and holds it just above the surface, but allows the metal blade to scrap the high icey spots. I got his idea from an old TractorByNet thread.
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
Weld on excavator thumb EK1212 (A56435)
Weld on excavator...
2015 Chevrolet Silverado 3500HD Knapheide Enclosed Service Truck (A56858)
2015 Chevrolet...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2019 Deere 550K (A53317)
2019 Deere 550K...
