KIOTI 4010 cab tractor AC
   / KIOTI 4010 cab tractor AC #1
Dashry1
Nederland,Texas
MF 4346
I know it’s cooling down however I have put off the AC system on my tractor. Blows air however will not blow cold A/c what would be the steps to trouble shoot?
   / KIOTI 4010 cab tractor AC #2
Have you checked the compressor belt for sufficient tension?
   / KIOTI 4010 cab tractor AC #3
Try blowing out the radiator and the condenser on the front of the tractor. My NS4710 is very sensitive to trash and debris getting in the fins. Even if it looks clean, clean it anyway. If you don’t clean it regularly, the system could start heating up and cause the compressor to fail. Easiest way to do this is to get an air comb. You can get them from Amazon for $30 or $40. If you are doing dusty work like brush cutting, clean it daily. May even need it more often if you’re cutting tall dry sage brush.
Thanks for the responses one thing I didn’t mention towards the end of the season there was a loud squealing nose that would last for 10-20 seconds at startup. Also all radiators and condensers are clean minimal trash.
   / KIOTI 4010 cab tractor AC #5
That sounds like the compressor belt is loose, or the compressor is having a problem.
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
