Kioti 2410 wont start
   / Kioti 2410 wont start #1
BigJoe67
Kioti CS2410
I have a Kioti CS2410 which will crank but not fire. I have replaced fuel filter and fuel pump. Taken hose off at fuel injector and when i run the pump, diesel flows. I have no smoke when it cranks. Not sure where to go from here
   / Kioti 2410 wont start #2
Check the fuse for the starter solenoid….
I believe it was the solution in the following scenario. TBD
While checking relays and stop solenoid, I found wire was broken at spade connector. Replaced connector and all is good. Thanks for the responses.
More info coming soon! (A48081)
More info coming...
Giant Elevator (A49251)
Giant Elevator...
1992 Effer 7600 2S Knuckleboom (A49346)
1992 Effer 7600 2S...
Job Box (A49251)
Job Box (A49251)
2008 Ford Crown Victoria Sedan (A48082)
2008 Ford Crown...
WHEEL LOADER BUCKET (A46683)
WHEEL LOADER...
