King Kutter XB
/ King Kutter XB #1
Dano97471
SW Oregon
Kubota B2920
What I would like to know is if a King Kutter XB landscape rake and rear blade will fit a B2920. I understand that the XB series implements are made for the SCUT.
/ King Kutter XB #2
I cant see why not. I have used my XB boxblade on my dad's John Deere 3720 with no problems. :thumbsup:
/ King Kutter XB #3
Should work just fine. Smaller implement + bigger tractor will almost always work, you just have to deal with issues of tire width vs. implement width and being careful not to destroy the implement with too much horsepower. Reverse is not as workable... big implement + small tractor presents obvious problems.
/ King Kutter XB #4
I've also used an XB boxblade on BX's, B's and an L.
/ King Kutter XB
Thanks guys...a neighbor has a 60" KK xb landscape rake for $300 and a 60" rear blade for $200 for sale.
/ King Kutter XB #6
Those should work fine, but be aware that the 60" blade probably won't cover your tracks when angled all the way. I have been half keeping an eye open for a rear blade, and landscape rake for my B2620, but think that I will get lighter duty 72" models instead. The smaller B's (B2320, B2620, and B2920) are kind of in between on hich size, and height, etc. so you just have to use a little common sense weight wise, and height wise. The tractors themselves are almost a perfect size for many small land owner's needs.
/ King Kutter XB #7
I have a Woods Estate lanscape rake (sub compact model, just like the XB) that I bought when I had a BX. I use it behind a B 2620-no problem, for the clean up and driveway maintenance I do. I'd like to have a full profile rake, but not enough to trade mine and $$$ for one.
The one warning I'd give on the blade, is that the moldboard will be shorter- probably not a problem for dirt work, but it can make snow removal a chore.
Will
2019 CATERPILLER 249D SKID STEER (A65056)
2019 CATERPILLER...
2018 MAGUNS  VACUUM/POWER WASHER TRAILER (A67714)
2018 MAGUNS...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2014 Impala Limited Sedan (A66738)
2014 Impala...
