King Kutter Spindles
/ King Kutter Spindles #1
grainger12002
Platinum Member
Pomfret,Connecticut
yanmar 336d w ldr,Cub,many attachments
any ideas on markets for replacement spindles, mower is only 5 years old....
/ King Kutter Spindles #2
on a rear finish mower?
Sorry about that-It seems I am always the only one who knows what I am thinking before finishing my written thought....................................It is a finish mower
Thank you
/ King Kutter Spindles #4
i got the same problem, tractor supply wants $100 each, $300 repair on a $900 mower after about 6 years use, does not seem right
/ King Kutter Spindles #5
Don't feel bad guys. My Bush Hog 6' finish mower has about the same crappy set up and must be greased every 4 hours or the wheels won't swivel. The crappy wheel bearing is a pipe and bushing which is severly worn after probably 60 hours. I don't have a clue what mine will cost but there won't be another Bush Hog in my barn unless they change this piss poor set up.
Dale
/ King Kutter Spindles #6
I made some for my king kutter mower. I put more draft in the bracket to make it not slide in turns. Made it out of 1/2 x 2 flat stock. Had the tires foam filled seems like I had flats all the time from sliding the tires sideways. Got the mower very used. Rebuilt two of the blade spindles with bearing from bearing house am still using them 5 seasons later. The one that I did not redo bearings I have replaced twice. I wil take pictures of brackets and post after weekend. big dan
/ King Kutter Spindles #8
shurly you jest....
the MMM on my TC is a $3000 option. a rhino or simular RFM is like $1500.... I defently think this falls under the "you get what you pay for" catagory....
can you not rebuild them yourself with some decent bearings instead of the cheep chineese chit they used?
/ King Kutter Spindles #9
You can probably rebuild them yourself. Once you have one apart and find the bearing number either buy locally or over the internet. Will save you a LOT of money. It's not hard to repair.
/ King Kutter Spindles #10
I just had to replace one of the spindles on my 6ft KK FM just this week. Tore into the old one hoping to just be able to replace the bearings, and when I got the shaft out, it was severely galled where it was riding in the failed bearing :mad:. Actually, the bearing hadn't failed yet, but it was pretty rough.
So, I had to go with a complete new spindle... with tax it was just under $87, and took all of about 10 minutes to replace. This is my mower's 7th season, and this is the first major repair I've had to do on it. Not too bad for el Cheapo I'd say!
Unused 2023 USA Manufacturing Hydraulic Thumb Excavator Attachment (A66734)
Unused 2023 USA...
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
2007 MACK VISION (A67714)
2007 MACK VISION...
2020 KENWORTH T880 (A67714)
2020 KENWORTH T880...
2013 BIG TEX T/A UTILITY TRAILER (A67714)
2013 BIG TEX T/A...
2018 Mitsubishi Eclipse SUV (A66738)
2018 Mitsubishi...
