Kinco KMG38 Sickle Mower
   / Kinco KMG38 Sickle Mower #31
could you send me a PDF file of the manual, I recently picked up a KMG 38 at a yard sale and have no information on it, would be great if you could send me a copy of the manual,
send to rayseguin@telus.net
   / Kinco KMG38 Sickle Mower #32
Harl,
Did you get the Sickle going? I have the same problem. I'm now considering buying a new carb.
Pw
   / Kinco KMG38 Sickle Mower #34
Took the motor apart to change leaking seals on both output shafts and will also seal up the oil filler spout where it joins the motor, still no luck finding a manual, I have the Tecumsa engine.
   / Kinco KMG38 Sickle Mower #35
   / Kinco KMG38 Sickle Mower #36
Here are some pics as I removed my Tecumseh carburator. Tecumseh carburator govenor linkange connection.jpg Tecumseh throttle linkage to carburator.jpg Tecumseh Carburator air intake.jpg top view.jpg
   / Kinco KMG38 Sickle Mower #38
I may have a copy of the 3.5 Tecumseh 2-cycle motor manual, depending on the vintage, if you still have a need.
This manual covers the following basic type or model
numbers dependent on age of product: AH520, AH600,
AV520, AV600, HSK600, TVS600.
This manual covered many engines under an Old form of
Identification which will need to be reviewed as well.
TYPE / SPECIFICATION NUMBER 638-670 1398-1642 and
Craftsman 200 Series Models.
   / Kinco KMG38 Sickle Mower #39
Kinco KMG-38 V belt obtained from Tractor Supply. Correct size is 1/2 inch by 38 inches. 0.5 in by 38 inch v belt.jpg
   / Kinco KMG38 Sickle Mower #40
My Kinco KMG-38 with a Tecumseh got a replacement carburetor that I ordered online. It needed no adjustments after installation.Carburator box top view.jpg Tecumseh 3.5 hp replacement Carb.jpg
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
50' Truck Scale (A51573)
50' Truck Scale...
2005 John Deere L118 Automatic 42in Riding Mower (A51694)
2005 John Deere...
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
2018 HAMM H7 SMOOTH DRUM ROLLER (A51246)
2018 HAMM H7...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
