Killing brush and weeds the easy way !!
   / Killing brush and weeds the easy way !! #21
We have a 30 gal sprayer. The tank is too small! Pretty much I think it would be too small at 50 gal too. I have to mix up 3-4 tanks to do the yard and 5-6 to do the fields close to the house. (foot plots). PITA.
Maybe you have a smaller area to do? If not, the tank will shrink from great to tiny in no time!:laughing:
   / Killing brush and weeds the easy way !! #22
I use the 16 gal Northern Tool boomless broadcast/spot sprayer.
By the way - It is on sale right now if you are in the market:
Item# 268110 Was $170 - on sale for $140
I strap it to the back on wifey's 4 wheeler for permethrin (tick killer) and glyphosate.
I added some quick connects to the power cable from Radio Shack (like these: 2-Position Male Interlocking Connector - RadioShack.com)
Just pull the sprayer off and unplug the power cable.
Works well.
I'll likely convert it to a pull behind this summer as she starts riding the 4 wheeler more. Right now, I just leave the sprayer strapped to the rear rack.
It def. saves a lot of time over pump sprayers.
I wish I had gotten the larger (25 gal i think) one but I was afraid it would add too much weight to the wheeler on hills.
So far, so good tho.
jw
   / Killing brush and weeds the easy way !! #23
Have any of you ever sprayed Remedy along the fencelines? It is the RoundUp opposite for killing off trees yet leaving the grass unharmed. I use it on small poplars and willows, works great. The leaves just shrivel up and the tree dies off.
The active ingredient in Remedy is triclopyr. I have used Crossbow, which contains 2-4,d and triclopyr (at a lower concentration than Remedy). Crossbow is pricey -- I think I paid $160+ for the last 2.5 gallon jug i bought. I have been thinking about switching to Garlon, a herbicide with a higher triclopyr concentration that Crossbow. So, what are you paying for Remedy?
Steve
   / Killing brush and weeds the easy way !! #24
I bought a 15 gallon spray electric spray rig from Harbor Freight for $99.00 and a Chicago Electric jump start power pack from HF for $39 with a coupon and today the Mrs. and I put both in the pack of our pick up filled with weed, grass and brush killer and drove the farm...along fence lines , around trees, along the edges of the road and wherever we saw that invasive privet.....
Now that was great ....it took about 2 hrs. for what used to be a 2 day job with our little pump up sprayers..If you have much land at all..this would be worth you looking into...:)
Ah, the 'ole Eco-Assault Vehicle trick... One of my personal favorites. Load it up with Tri-Ox next time :).
JayC
   / Killing brush and weeds the easy way !! #25
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
10x16.5 Tire Assembly (A51039)
10x16.5 Tire...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
2022 JOHN DEERE 332G (A50854)
2022 JOHN DEERE...
2018 Wacker Neuson WL 38 (A51039)
2018 Wacker Neuson...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
