Killing brush and weeds the easy way !!
   / Killing brush and weeds the easy way !! #1
brin
Super Member
Georgia - Mt. Vernon by The Store just 5 miles eas
I bought a 15 gallon spray electric spray rig from Harbor Freight for $99.00 and a Chicago Electric jump start power pack from HF for $39 with a coupon and today the Mrs. and I put both in the pack of our pick up filled with weed, grass and brush killer and drove the farm...along fence lines , around trees, along the edges of the road and wherever we saw that invasive privet.....
Now that was great ....it took about 2 hrs. for what used to be a 2 day job with our little pump up sprayers..If you have much land at all..this would be worth you looking into...:)
   / Killing brush and weeds the easy way !! #2
i bought a new sprayer like you bought last year from TSC for $59.but i havent used it yet.
   / Killing brush and weeds the easy way !! #3
It looks as if I'll be buying me something like that because the poison oak/ivy has almost taken over in spots. I plowed up a spot about 50' by 100' near the side of the road and planted some grass in hopes of choking it out instead of constantly spraying. This area had 1 large oak tree and lots of other small brush until the tornado last April took out the large oak. I have much larger spots left to go and tired of pumping !!!.
   / Killing brush and weeds the easy way !! #4
I got goats, Just gotta open the pen gate.
Steave...I bought the sprayer and power pack so I could use it from my truck, ATV or tractor and it sure does save a lot of time and works like a charm...I got the Brush Killer which is 41% Glosphate ( not sure of the spelling but what kills the brush , grass and weeds ) from Home Depot on line...It was 1/2 the price of Roundup...$39 for 2 & 1/2 gallons of concentrate and we used it last year and it worked great. It is called " Compare and Save " but our local HD store did not have it so we got it from their on line site with free shipping...It guarantees a 1 yr. kill and I can attest to that.
   / Killing brush and weeds the easy way !! #6
Could you not just get a 12V power cord that plugs into the cigarette lighter and run it off of the trucks electrical system?? Depending on how much current the pump motor draws, the tractor and/or atv may also have enough power to run it? Just a thought anyway.
Yes...on the tractor and ATV I use the cigarette lighter but I don't have on in the truck so I bought that power supply for $39 from HF ...I can use it for jump starting and other things as well..whereas a cigarette lighter in the truck would not have any use other than this...but good point ...you could also just use the alligator clips onto the vehicles battery..that would work too.
   / Killing brush and weeds the easy way !! #8
That's what I do with mine and the riding lawn mower. I put the 15 gal. sprayer in a pull behind trailer and ran a wire to the battery terminals and ran the hand wand up so I can spot spray and never leave the seat! :thumbsup:
   / Killing brush and weeds the easy way !! #9
You're spray set up sounds good. A more permanant solution is to pull it out of the ground with your tractor or four wheeler. I used to use Round Up which would knock it back for a year so, then it would come back. Pull it out and burn it and it's gone for ever. Those herbicides can get expensive.
   / Killing brush and weeds the easy way !! #10
i really get a lot use out of my 15 gallon spot sprayer from Northern Equipment - for spraying fence i purchased an 18" spray handle - it's less of a reach than the handle that came with it.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2013 CHEVROLET SILVERADO 2500HD (A50854)
2013 CHEVROLET...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
2013 HINO 388 (A50854)
1997 John Deere 8100 MFWD Tractor (A51039)
1997 John Deere...
