kill switch?
/ kill switch? #1
2516mo
Missouri
2010 mahindra 2516 gear
Living in a suburban area, I wanted to see if anyone has installed or had experience with adding a kill switch to disable their tractor.
I will be parking my 2516 outside and wondered if I needed to go the extra step of disabling it.
/ kill switch? #3
Simple.
Cut the starter relay wire and insert a hidden switch into that line.
Maybe up under the dash where you can reach it.
On my tractor there is a switch to prevent starting in other than neutral and I simply unplug one of the leads from the switch.
/ kill switch?
Great idea thanks!
/ kill switch? #5
even better .... wire it into a 2 way switch that goes the starter and to a horn instead .... flip it, and any attempt to start it now sounds the horn
/ kill switch? #7
disconnect one wire and add the switch in there (neutral start )
Simple.
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2013 CHEVROLET TAHOE (A66091)
2013 CHEVROLET...
2004 CASE CX75SR EXCAVATOR (A65056)
2004 CASE CX75SR...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
2023 Kubota Z781KWTI 62in Zero Turn Commercial Mower (A66734)
2023 Kubota...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
