kill switch?
/ kill switch? #1
2516mo
Missouri
2010 mahindra 2516 gear
Living in a suburban area, I wanted to see if anyone has installed or had experience with adding a kill switch to disable their tractor.
I will be parking my 2516 outside and wondered if I needed to go the extra step of disabling it.
/ kill switch? #3
Simple.
Cut the starter relay wire and insert a hidden switch into that line.
Maybe up under the dash where you can reach it.
On my tractor there is a switch to prevent starting in other than neutral and I simply unplug one of the leads from the switch.
/ kill switch?
Great idea thanks!
/ kill switch? #5
even better .... wire it into a 2 way switch that goes the starter and to a horn instead .... flip it, and any attempt to start it now sounds the horn
/ kill switch? #7
disconnect one wire and add the switch in there (neutral start )
Simple.
PORTA POTTY (A67714)
2003 FORD F-750 SUPER DUTY(INOPERABLE) (A67714)
2003 FORD F-750...
2016 Ford F-550 Auto Crane 4004EH Service Truck (A64556)
2016 Ford F-550...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
WELDING TABLE (A68842)
3 PALLETS OF SNOW CHAINS (A66091)
3 PALLETS OF SNOW...
