sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,757
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
When you jumped the terminals you were shorting the large terminal to the small one on the solenoid. the large terminal is directly hooked to your battery + terminal. since the starter spun I believe something between your key switch and solenoid has come loose or broken. You may need to get a friend that can use a multi meter to help find first if voltage is getting from the key switch to the start switch to the safety interlock switch to the small terminal on the solenoid. This can be dangerous if the tractor is not in neutral. A safer way is to disconnect the battery and use an ohm meter to look for continuity thru each switch and between them until it is traced all the way to the solenoid. Very glad to hear there's no major structural damage.
