Key Blanks
/ Key Blanks #1
quailman115
North Florida
2310D
Does anyone have any idea where I can find Yanmar key blanks - need a couple for extra keys.
Thanks,
William
/ Key Blanks #2
Hoye Tractor and Equipment has them listed on their web sight. I guess from what I see they are blank keys. I gave and just replace the whole switch for about 15 dollars
/ Key Blanks #3
Any good locksmith will have the blanks or can order them. Good locksmith does not include your Walmart or similar copy key shop. And as posted, the dash key hole will accept almost any Napa etc. universal ignition set up.
/ Key Blanks #5
JD part # CH12206 2 keys in a pack for app. $5. Fits all later Yanmar ignition switches.
/ Key Blanks #6
William:
To be a little more precise and since you didn't specify year and model. We have Yanmars from 1978 in YMs, F, and FX, and later and up to 1995 in Ke3 and F models. The keys are not the same and there at least 5 different key configurations but all are still available at a good key shop and key copies should at the most be $2 each.
/ Key Blanks #9
I've had the following models, all of which used the same key. They may have looked different, but the part that goes in the switch was the same.
YM1110D
YM1301D
YM1500D
YM1510D
F15D
And I believe it was the JD CH12206.
I cannot swear to it, but I think the YM1601D, YM1702D, and YM2210D all used the same key as well.
/ Key Blanks #10
It seems like all the YM1510 and bigger 3-cylinder YM's take the same JD key that LMTC described, the YM1401 is different, although I have had keys made for it at a local key shop. Some of the F and FX's take the JD key, but I have found the 3 digit F series takes a different key. Dave
/ Key Blanks #11
Greg & Dave are correct. All the 1702d, 1601d, & 1510d's that I have sold have the same key. The 1401d uses a different key.
Jim
/ Key Blanks #12
I replaced out the key switch on my 1700 with an echlin (sp? ) still only had 2 keys though..so and then took that key to a locksmith, and he found a very close blank to it to copy it for me as well.
Soundguy
/ Key Blanks #13
I go to a JD dealer and get generic compact tractor keys. Works without any key cutting required.
/ Key Blanks #14
I Have 23 extra keys for yanmars at 5.00 each
how many do you want?
Ernie
/ Key Blanks #16
You Bet I am !
Im also sellin the leaves all over my lawn.
Any buyers ??
On a serious note:
My wife is starting to talk about my yanmar parts pile outside
tillers, wheels, tiller parts ect.. (it aint pretty)
Possible yanmar yard sale comin up soon.
Ern.
/ Key Blanks #17
Do you have one for an F15D?
If you do Email me I'm interested in one. ushighway6@yahoo.com
I would be interested in some wheels also if you have any I could use.
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2354 (A64281)
2354 (A64281)
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
Adams 16T Tender Body (A63688)
Adams 16T Tender...
