Keeping implements outside..keep away rust?
   / Keeping implements outside..keep away rust? #11
I don’t like equipment sitting outside but I don’t mind so much for the attachments to sit outside. Keep the bare metal with the exception of the ground engagement parts painted and it’ll never rust out in one lifetime. The paint will fade but that’s not a big problem either. You could always invest in a prefab carport or consider adding a lean to one of your existing buildings.
The tarp was only to keep them kubota orange maybe one with air vents for the wind to pass. Trouble is i want to buy a grass bagger and they look to take up a ton space.....since it never snows anymore all i get to do is cut the grass. :)
   / Keeping implements outside..keep away rust? #13
You should grease and fluid film the blower if you leave it outside. With a tarp you will draw all kinds of critters.
   / Keeping implements outside..keep away rust? #14
I have a portable garage that covers my stuff. When I pack the summer stuff away for the winter I by Plastic painting tarps ( Walmart) and lay those on the ground. Amazing how much moisture gets captured that would otherwise rise up from the bare ground under the equipment.
   / Keeping implements outside..keep away rust? #15
Not a fan of tarps. Most of my "stuff" is in the dry. Right now my 10 foot cutter is out in the open. I removed all the debris and sprayed it down with fluid film. I started using it years ago and it works good for me.
   / Keeping implements outside..keep away rust? #16
I would store the blower inside or under a cover. I have a blade and rake that were stored outside for thirty years and they work fine. The rototiller, mmm. and brush hog look like crap but still work. Now that I own them I store them inside. A big reason is that I have my attachments on dollies to make them easy to move around and attach.
Looking at adding a carport for storing tractor, and firewood. If I put my attachments under the carport I would need to get a quick hitch as I do not plan to put a cement pad in.
As others noted, spraying with a rust preventative is a smart thing to do in any case.
   / Keeping implements outside..keep away rust? #17
To support the consensus...
Not WD40 and not a tight tarp.
I spray with White Lithium grease for basic rust prevention but you get the idea.
I set all my gear on 2" of gravel minimum or a wood pallet/crate if it has to be outside.
Otherwise, I stuff it in the empty stall of my barn and let the cat hunt around it.
South Carolina is pretty easy on equipment if its properly coated (other than UV).
RGAZ
   / Keeping implements outside..keep away rust? #18
Off the earth, LPS-3 protectant on non painted parts before the winter. I do plan on building a lean to, but with the wind in my area it is more of a challenge. Airflow is important, keeping rain off as well.
   / Keeping implements outside..keep away rust? #19
Why are tarps mostly that hidious blue? Makes a place look unecessarily junky.
   / Keeping implements outside..keep away rust? #20
I use the brown ones. Look a little less "country" but not much...
Not super fond of tarps though. They can hold moisture in, and make it even more comfortable for the varmints. Fortunate enough to be able to park my orange gear under an open shed roof, and generally out of the rain. I do spray the chrome parts with LPS-3 if they're going to sit for very long.
Z.
2022 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A55973)
2022...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
SET OF PRECAST STEPS (A58374)
SET OF PRECAST...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
ALUMINUM STEP LADDER (A52708)
ALUMINUM STEP...
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A57453)
2016 Hino 195h...
