KE70 question
/ KE70 question #1
CanadianBeaverS370
St-Telesphore,Qc
Satoh Beaver and IH B414 FEL
Hi Guys
Does any one have an exploded view of this engines assembly? The reason I ask is that I am looking for and access point to the water Jacket other than the temp sensor provision. I noticed on the lower side of the block between the starter and altenator there is a 3/8 ish bolt. I loosened it an it looked like coolant oozed out. I want to know if I can put my mechanical temp sensor there. I don't want to drain the rad just to find out... I looked for the provision on the water pump as stated by some other guys on this forum, unfortunately I could not us that port for my senor as it has a coolant line that goes to the bottom of the thermostat housing. Any help or advice is greatly appreciated :thumbsup:
BTW the KE70 is in a S370 beaver.
/ KE70 question #2
There is a point on the starter side of the block where you'd find what might be a drain plug. Forget what size it is.
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
New/Unused ATS Electric Jack (A65583)
New/Unused ATS...
2001 Mack Grapple Truck (A64127)
2001 Mack Grapple...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
