kb2375 backhoe broke again
/ kb2375 backhoe broke again
What matters is do YOU think it is a good deal? Are you able to afford to move into another BH at this time and do you use any BH enough to justify the price of a trade? Or do you want to find out what it will cost you to refix this one, hopefully permanently- with the suggested mod of the capped pin with built in Zerk?
If you can afford a trade it might be your best bet- but remember it only comes with a 1 yr. warranty.
Im on the fence about the trade in, I do use the backhoe a good amount.
From what Kioti told me on the phone, at best only parts will be covered, so money will be coming out of my pocket no matter what the outcome.
I like the custom pin that Avondale made, I dont have the ability to make such a part and Im sure my dealer would put it right to me to make that.
As far as, "If I think its a good deal" I have always been the type of person that looks at, will I get my money back if I need to sell it or trade it in on something else.
Ken
/ kb2375 backhoe broke again #12
The OEM pins have zerks but I do not think grease is an issue with regards to these failures. My problem was the pin falls out when the retaining bolt breaks. Bouncing on rough roads will surely break these small bolts regardless of grade. Once a pin has fallen out (upper or lower) the BH is free to roam off the hinge plates and damage will occur with that much weight blowing in the breeze. Damage can occur while tractor jostles down the rough path or while in use, slewing with one pin gone will throw the BH off the frame hinge plate and the cyl will break off.
The cap is not the only solution, i.e. weld on a retaining clip across the top, build a catch screen on bottom, etc. I am lucky to have work at a place that can easily machine stuff but would think a simple design such as mine would not be very expensive at most machine shops. IF your dealer is a real good guy, he may know someone in the machine shop biz to solve this at a very reasonable price. If the replacement BH has not resolved thie original issue, you may well face this problem again and be that much poorer for it.
/ kb2375 backhoe broke again #13
Avondale, what steel did you use? did you harden it?
AMERICAN 14 T/A DOG HOUSE (A60736)
AMERICAN 14 T/A...
PREVIEW DATES AND TIMES (A61166)
PREVIEW DATES AND...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2020 DRAGON ESP...
