KAMA TS254C starter
/ KAMA TS254C starter #62
Good going Jeff,
You got a lot out of your solenoid then, because I had problems with mine right away until I fixed it. It's been great since then. I did have some other electrical issues and I think all that was contributing. I worked without the dash working for several months before my friend Larry came over to help me fix the starting problem and the rest of the electrical circuit by changing out the stock fuse panel with an automotive type. I've got way over 500 hours (off the clock) and 480 on the clock now.
/ KAMA TS254C starter #63
lakespirit said:
450 hours.
If you used your tractor for 450 hrs before you had this problem and fixed it by cleaning the solenoid and replacing the starter brushes, I would think that you may get another 450 hrs of use. Sometimes a little low grade maintenance will preclude expensive replacement.
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
New Holland 273 Square Baler (A66408)
New Holland 273...
1987 Kenworth T800 Day Cab (A62613)
1987 Kenworth T800...
