KAMA Flywheel Housing
/ KAMA Flywheel Housing #11
I thought the fenders were sharp also. Problem is they didn't work with a loader attached. I modified the brackets on mine to allow them to fit. Not that they are necessary but I thought they look cool! .... Scozz
/ KAMA Flywheel Housing #12
Check with your dealer. The hitch with the grease gun is that it will not accept a standard tube of grease, have to fill it by hand I guess, but it does have a pointly little tip, not zerk fitting but can greas zerk becauseit is small enough to go into the hole. We did not get these with all the tractors and the ones with zerks don't need it.
The weights don't come with tractors equpped with loaders normally, and they serve no function on the tractor. too expensive to ship after the fact, truth is they end up on a "scrap pile" although we have used a few for various ballast, I use one in my Ural sidecar if I don't have a passenger.
The fenders were disconitnued in early 2005 or late 2004 also we had to remove them if we installed a loader or reduce the turnging radius so the fender would not hit the loader brackets.
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
1999 John Deere 7810 (A60462)
1999 John Deere...
2022 John Deere 5090E (A60462)
2022 John Deere...
International S1900 (A61307)
International...
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
