KAMA 454 tach sensor
/ KAMA 454 tach sensor #1
Paddy
Bloomington, IN
Kubota, G5200, KAMA 454
My Tach has not worked in years. So I gave it a look see today. I pulled it out and it looks fine. I tried to measure continuity/ohms but it showed none. I cleaned the end and reset it, 1/2 turn from touching.
Fired up the tractor and measured AC V from sensor harness and it was 0.1 V at the highest. dancing around about 0.06.
Bad sensor?
A side question; Is member Blue Chip of Artrac still posting to this site?
/ KAMA 454 tach sensor #2
Bad sensor?
There is no continuity in a "Mag pick up". They are simply what I call a "Tooth counter". Every time a tooth passes by an AC pulse signal is created which is sent to the tachometer.
Thank you Bob. does the 0.1 V AC sound good?
/ KAMA 454 tach sensor #4
I think it should be, but it depends on the trigger threshold of the tach, which I have no idea what that is. As long as you're getting voltage the main thing is the pulses, they should correlate to one of the scales on your VOM.
2013 GMC Sierra 4x4 (A62613)
2013 GMC Sierra...
INSPECTION (A65563)
INSPECTION (A65563)
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
2023 JOHN DEERE 333G SKID STEER (A64277)
2023 JOHN DEERE...
