KAMA 454 tach sensor
/ KAMA 454 tach sensor #1
Paddy
Bloomington, IN
Kubota, G5200, KAMA 454
My Tach has not worked in years. So I gave it a look see today. I pulled it out and it looks fine. I tried to measure continuity/ohms but it showed none. I cleaned the end and reset it, 1/2 turn from touching.
Fired up the tractor and measured AC V from sensor harness and it was 0.1 V at the highest. dancing around about 0.06.
Bad sensor?
A side question; Is member Blue Chip of Artrac still posting to this site?
/ KAMA 454 tach sensor #2
Bad sensor?
There is no continuity in a "Mag pick up". They are simply what I call a "Tooth counter". Every time a tooth passes by an AC pulse signal is created which is sent to the tachometer.
Thank you Bob. does the 0.1 V AC sound good?
/ KAMA 454 tach sensor #4
I think it should be, but it depends on the trigger threshold of the tach, which I have no idea what that is. As long as you're getting voltage the main thing is the pulses, they should correlate to one of the scales on your VOM.
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
2016 FORD F-550XL SUPER DUTY SERVICE TRUCK (A64280)
2016 FORD F-550XL...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
(15) UNUSED 3 1/2' X 8' PLASTIC PROTECTION MATS (A64281)
(15) UNUSED 3 1/2'...
(2) 4 WAY WRENCHES (A64276)
(2) 4 WAY WRENCHES...
