KAMA 454 tach sensor
/ KAMA 454 tach sensor #1
Paddy
Veteran Member
Bloomington, IN
Kubota, G5200, KAMA 454
My Tach has not worked in years. So I gave it a look see today. I pulled it out and it looks fine. I tried to measure continuity/ohms but it showed none. I cleaned the end and reset it, 1/2 turn from touching.
Fired up the tractor and measured AC V from sensor harness and it was 0.1 V at the highest. dancing around about 0.06.
Bad sensor?
A side question; Is member Blue Chip of Artrac still posting to this site?
/ KAMA 454 tach sensor #2
Bad sensor?
There is no continuity in a "Mag pick up". They are simply what I call a "Tooth counter". Every time a tooth passes by an AC pulse signal is created which is sent to the tachometer.
Thank you Bob. does the 0.1 V AC sound good?
/ KAMA 454 tach sensor #4
I think it should be, but it depends on the trigger threshold of the tach, which I have no idea what that is. As long as you're getting voltage the main thing is the pulses, they should correlate to one of the scales on your VOM.
LOAD OUT AND SHIPPING (A61166)
LOAD OUT AND...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
2010 GMC Acadia SL SUV (A59231)
2010 GMC Acadia SL...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
