k- 45 koita tractor transmission problem
   / k- 45 koita tractor transmission problem #1
charley40
Hello. I have a k- 45 with a transmission problem. Pulls great in all gears with the exception of third and forth. Will not move from a stand still while in these gears. Just seems to slip does not do this in any other gears, reverse works perfecty and will move maxium load, only 240 hrs. since purchased new. What is wrong? Seems like a bad clutch would effect all gears, not just third and forth.
Need help on this one.
Thanks,:
   / k- 45 koita tractor transmission problem #2
Welcome to TBN. :)
   / k- 45 koita tractor transmission problem #3
Hey Charley40! Welcome to TractorByNet! :D I have moved your thread to the Kioti Owning/Operating Forum. You will have better luck finding what you need there. :thumbsup:
   / k- 45 koita tractor transmission problem #4
Thanks,:
Will third and 4th work in low range? It is typical for a slipping clutch to be able to drive a tractor in lower gears, higher gears have more resistance to overcome to move. do you have a good inch or so of free travel on the clutch pedal?
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
2003 Big Tex 10PI...
NEW Fork Extensions (A59000)
NEW Fork...
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
2018 KENWORTH T800 HOTOILER (A58214)
2018 KENWORTH T800...
