k- 45 koita tractor transmission problem
   / k- 45 koita tractor transmission problem #1
charley40
Hello. I have a k- 45 with a transmission problem. Pulls great in all gears with the exception of third and forth. Will not move from a stand still while in these gears. Just seems to slip does not do this in any other gears, reverse works perfecty and will move maxium load, only 240 hrs. since purchased new. What is wrong? Seems like a bad clutch would effect all gears, not just third and forth.
Need help on this one.
Thanks,:
   / k- 45 koita tractor transmission problem #2
Welcome to TBN. :)
   / k- 45 koita tractor transmission problem #3
Hey Charley40! Welcome to TractorByNet! :D I have moved your thread to the Kioti Owning/Operating Forum. You will have better luck finding what you need there. :thumbsup:
   / k- 45 koita tractor transmission problem #4
Thanks,:
Will third and 4th work in low range? It is typical for a slipping clutch to be able to drive a tractor in lower gears, higher gears have more resistance to overcome to move. do you have a good inch or so of free travel on the clutch pedal?
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
Great Dane Van Trailer (A56435)
Great Dane Van...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2014 BMW X1 S Drive 28I SUV (A56859)
2014 BMW X1 S...
