k- 45 koita tractor transmission problem
   / k- 45 koita tractor transmission problem #1
charley40
Hello. I have a k- 45 with a transmission problem. Pulls great in all gears with the exception of third and forth. Will not move from a stand still while in these gears. Just seems to slip does not do this in any other gears, reverse works perfecty and will move maxium load, only 240 hrs. since purchased new. What is wrong? Seems like a bad clutch would effect all gears, not just third and forth.
Need help on this one.
Thanks,:
   / k- 45 koita tractor transmission problem #2
Welcome to TBN. :)
   / k- 45 koita tractor transmission problem #3
Hey Charley40! Welcome to TractorByNet! :D I have moved your thread to the Kioti Owning/Operating Forum. You will have better luck finding what you need there. :thumbsup:
   / k- 45 koita tractor transmission problem #4
Thanks,:
Will third and 4th work in low range? It is typical for a slipping clutch to be able to drive a tractor in lower gears, higher gears have more resistance to overcome to move. do you have a good inch or so of free travel on the clutch pedal?
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
Unused Delta Crash...
