jx85
tonytoe
case jx85
where to get hydraulic power for loader bucket
The specs for your machine is open center and 13 GPM.
It also says standard valves 3 .
If you have just installed a loader, and no valve for it, then you need a joystick valve with PB to complete the circuit.
http://www.surpluscenter.com/item.asp?item=9-4782&catname=hydraulic
Hydraulics
• Standard Valves: 3
• Type: open
• Valve Flow: 13.6 gpm
General
• Manufacturer: caseih
• Model: jx85
• Series: sii_jx85.pdf'>pdf file
• years produced: 2002 - 2006
/ jx85
I have joystick,but I need to know where to get my hydraulic power from other than from the farm impliment supply ports
Can you tell me what you have for hyd from the pump to the reservoir?
If you have a loader, it may have a PB outlet.
What is your goal? Add more hydraulics, such as remotes at the rear.
If all you have now is 3pt, then the flow is from the pump to the 3pt, then reservoir.
If you have a loader the flow is probably from the pump to the FEL valve then to the 3pt , then to reservoir.
You have an open center hyd system, so all valves should be in series.
2025 X-Pro Victor Mini Dirt Bike (A61574)
2025 X-Pro Victor...
2007 Chevrolet Express 2500 Cargo Van (A61573)
2007 Chevrolet...
2005 John Deere 7420 (A60462)
2005 John Deere...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
JOHN DEERE 8330 TRACTOR (A63291)
JOHN DEERE 8330...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
