jx85
tonytoe
case jx85
where to get hydraulic power for loader bucket
The specs for your machine is open center and 13 GPM.
It also says standard valves 3 .
If you have just installed a loader, and no valve for it, then you need a joystick valve with PB to complete the circuit.
http://www.surpluscenter.com/item.asp?item=9-4782&catname=hydraulic
Hydraulics
• Standard Valves: 3
• Type: open
• Valve Flow: 13.6 gpm
General
• Manufacturer: caseih
• Model: jx85
• Series: sii_jx85.pdf'>pdf file
• years produced: 2002 - 2006
/ jx85
I have joystick,but I need to know where to get my hydraulic power from other than from the farm impliment supply ports
Can you tell me what you have for hyd from the pump to the reservoir?
If you have a loader, it may have a PB outlet.
What is your goal? Add more hydraulics, such as remotes at the rear.
If all you have now is 3pt, then the flow is from the pump to the 3pt, then reservoir.
If you have a loader the flow is probably from the pump to the FEL valve then to the 3pt , then to reservoir.
You have an open center hyd system, so all valves should be in series.
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
Tree Boom Skid Steer Attachment (A61572)
Tree Boom Skid...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
HOMEMADE TIRE DRAG (A63291)
HOMEMADE TIRE DRAG...
58in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
58in Hydraulic...
