Mowing JX60 clutch problem
/ JX60 clutch problem #1
4DD
ATHENS, TEXAS
CASE IH JX60
Hoping someone can help me ensure the clutch is the problem before I split this tractor.
I was mowing with my Case JX60 with 1200 hours. All was fine but noticed that the PTO shaft was turning slowly. I depressed the clutch just a little and the PTO sped up again. The jx has a 2 stage clutch so I looked at the PTO cable and noticed it had a lot of slack. Using the adjustment I took up the slack and fired up the tractor. I engaged the PTO and it ran great but when I let out on the clutch I didn't move! I put back some slack in the PTO cable and tried it again. Now the tractor clutch worked but the PTO shaft slip although not as much as before.
I need to know if this is symptomatic of the clutch starting to go out?
Thanks for any help or suggestion.
2022 EZ-GO ELITE...
Jack Daniels Sign (A64557)
Jack Daniels Sign...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
2004 John Deere 544J Articulated Wheel Loader (A64553)
2004 John Deere...
2024 CATERPILLAR CP56B PADFOOT ROLLER (A65053)
2024 CATERPILLAR...
SHOPBUILT S/A TRAILER (A64278)
SHOPBUILT S/A...
