Just wondering
/ Just wondering #1
Sprocket1
North Cen. Mo.
JD2305 JD5205
Has anyone mounted a boxblade in place of your FEL bucket? Seems it would easily done and really easy to use.
/ Just wondering #2
Heard almost the same thing the other day. Guy has a big snow box on the front of a cat loader. He was wondering if he could replace the rubber snow edge with a steel edge and use it to maintain dirt roads. Certainly sounds interesting /forums/images/graemlins/smile.gif
/ Just wondering #3
I can't imagine why one would want to put a box place on his loader in place of the bucket... /forums/images/graemlins/confused.gif
For me the box blade and the loader bucket work pretty much as a team.
I think the box blade on the loader arms would stress them in ways they were not designed for.
I would not do it myself...
/ Just wondering #4
I'm also thinking that the shock loads with the rippers down might be more that you want to subject your loader to. Besides if you did have a box blade mounted on the front what would you be saving the 3-point for? /forums/images/graemlins/confused.gif
/ Just wondering #5
I've seen it done on skidsteers and the power trac ads. They face "backwards" so, don't know about loader arm stress. I'm just finishing up a QA to 3 Pt. adapter just for this type of stuff. power trac pic
/ Just wondering #6
Interesting combination dummy do you have any more pictures of your machine?
/ Just wondering #7
I'm capable of mounting a Box Blade with a 3ph Quick Hitch that I modified to fit my FEL. I don't think it would work out as well there as it would on the 3ph because you cannot change tilt. You sure could get lots of top link adjustment with the dump cylinders. Especially if you do not have T&T on your 3ph.
I'll have to try putting it on the FEL next time I have a project.
/ Just wondering #8
I hijacked that one from the power trac guys! I'm building mine for my Allmand TLB (non-removeable hoe). And preliminary tests prove that lower hooks are a must have item. It probably would have been easier to split a 3 pt. quick hitch and weld it to a QA plate.
/ Just wondering #9
Personally I think you would bend up the arms on your loader. They get bent up pretty easy as it is.
murph
/ Just wondering #10
Sprocket1; I'm probably missing something here, as I'm accused of doing that alot. Anyway, aren't tractors, trucks and the like designed to pull from the rear end? I always smile at the guys with the monster hooks on the front of their pickemups that try to unstick another by pulling from the front. /forums/images/graemlins/crazy.gif Turn it around dummy, it'll work better. I've even demonstrated that a few times. /forums/images/graemlins/smirk.gif
Just for the stress factor on your arms, I don't think I'd try it. Then again, the photo of the Ventrac dragging in reverse makes me think again. /forums/images/graemlins/confused.gif
One more thing, the bottom line is, I really wouldn't want to take a chance on screwing up my loader, but if your bent on doing this, let us know how it works, it is an interesting idea. /forums/images/graemlins/grin.gif
/ Just wondering
It would seem to me that a box blade mounted on the front end wouldn't be much different than pushing a loader bucket with teeth on it. What would be different is it would be easier to keep the ground more level and smooth.
I don't have a BB, but I wouldn't be concerned about bending the FEL frame if I did.
The argument of being able to pull more than you can push reminds me of the age old question about the horse and plow. For those who never heard it before it is: Does a horse push or pull a plow? For those who don't know, a horse pushes a plow.
2014 Chevrolet Tahoe SUV (A64557)
2014 Chevrolet...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2010 FORD F750 BUCKET TRUCK (A63276)
2010 FORD F750...
Single Cylinder Hydraulic Grapple Bucket Mini Skid Steer Attachment (A64553)
Single Cylinder...
Yard Mailbox (A64557)
