Just ordered chains....man are they heavy
/ Just ordered chains....man are they heavy #21
What size tire do they fit, Jay?
Try the TBN Private Party ads...you might be able to sell them here.
They're 41x14x20 turfs. I'm not ready to toss them yet. With the performance I got out of those little front chains, I'm thinking that with all 4 tires chained, I could climb right up a tree. If I do decide to give up on them though, I'll try here first!
JayC
/ Just ordered chains....man are they heavy #22
JayC
Thought so (about the size)...same as on my Deere 4400.
41x14x20 Turfs are used on (Deere models) 4200, 4300, 4400, 4210, 4310, 4410 and probably the new 3x20 series machines. I'm sure they're used on a number of Kubota models too...as well as others.
The good news...shouldn't be too difficult to sell (if you decide to). The bad (or good) news is, due to the popularity in that size tire, tirechains.com will probably sell out fairly quickly.
Another local TBNer had the 2 link ladders. Heavy!!! Which is one reason I went for the 4 link ladders...
i was hemming and hawing over 2 link vs 4 link, and decided on the 2 link to try and get a quieter and less bumpy ride. well see how it works out. Oh by the way... i invited the neighbors over for tritip this Sunday hehe
yeiks...they just arrived. **** are they heavy.
OK, i went and installed one of the rear chains just to check how its done..... yeiks those are about 100# +.
Watched the video, then did the opposite :laughing:. I jacked up one side of the rear of the tractor and used the tire to pull the chain over itself. Actually worked slick. Had it installed in about 10 minutes.
Now setting and adjusting the binders took abit longer. I watched the video again and learned i was using the binder tool wrong. Now i got it all set.
Mind you, i had to remove the chains till we get ice....but shouldn't be too much of an issue.
when i ordered them i guess i didnt read that there 3/8" chain. that took me by surprise. im so use to car chains.
/ Just ordered chains....man are they heavy #27
JayC
Thats same size as my montana. Im gonna order my chains from those guys as even after shipping im over half the cost of here in canada. I looked it up today and its 1700 for chains up here and there 550 plus duty and taxes so makes a guy wonder who is gettin screwed. I installed fronts last year but they were too light so they only lasted a winter. I noticed my biggest difference with the fronts but my backs made a huge difference.
Yeiks... drive over and throw them in the trunk.....
/ Just ordered chains....man are they heavy #29
When a friend and I turned my rear wheels (more clearance for chains), he brought his 2 Link ladders over to show me. I knew what I was getting into! Since my drive is only 150' or so and level, 4 link ladders work just fine at considerably less weight.
/ Just ordered chains....man are they heavy #30
That's how I install my tire chains. The Tellesfdal chains are real easy since there are two chains that go around the tread that you connect first and then each side chain has a binder to tighten the chain up. You may find front and rear chains are over kill.
/ Just ordered chains....man are they heavy #31
This is the way I put my chains on also after many times of trial and effort. I dug them out today and spread them out on the garage floor. It was 65 degrees and sunny today. Same tomorrow. Hard to get in the mood but the chains are probably going on tomorrow.
ya, i just wasnt sure. This is the first year im using the snow plow, and ive contractod out 2-1/2 miles of roads to do. I just dont want something to happen where i cant handle the buildup.
/ Just ordered chains....man are they heavy #33
I safety wire everything after mounting my chains. If it's loose or a possibility that it may become loose it gets over killed with safety wire and pliers. Tight and tucked. When it snows that's all I want to take care of. Not the tweaking of my tire chains in the middle of a snow storm.
/ Just ordered chains....man are they heavy #34
Because my chains have two chains that go around the outside of the tire on top of the tread I get those as tight as I can. The chains have binders on each side chain so I can tighten the chains very tight. I know they say leave them loose but with them tight they don't move around and I don't have to worry about the spring things to keep tension on them. The only thing that could loosen up are the shackles that keep the binder levers tight and I use an adjustable to snug up the pin.
/ Just ordered chains....man are they heavy #35
www.tirechains.com recommends those chains be tight for most durability. Apparently, floppy chains can wear pretty quickly.
I've never heard of anyone suggesting they be a bit loose...not for snow, at least...and definitely not if they're to be used on pavement.
/ Just ordered chains....man are they heavy #36
Yep thats my plan lol. Its rediculos what they are worth up here. cant afford them otherwise. I need new chains all the way around this year. I would build my own but it isnt worth it.
/ Just ordered chains....man are they heavy #37
Tellesfdal recommends you leave them loose. I can't remember how loose but I don't always follow directions. Who knows, maybe they grip better loose or maybe they wear faster forcing you to replace them sooner, I don't know the reason why they say loose but I'll never find out because I like them tight.
/ Just ordered chains....man are they heavy #38
I used the 4 link v-bars on all 4 tires last winter and for my 300+ foot gravel driveway I did not notice the ride being too bumpy. On the gravel drive and the 1/2 mile of graded dirt road I help plow/blow I don't expect too smooth of a ride anyway but if I was on concrete or blacktop I might feel the difference. I will say that I felt VERY secure when things got icy even with the 4 link vs 2 link. With only an inch on the ground at my elevation I am having a hard time talking myself into putting them on. I lay them out and drive on them then readjust a couple of times until I get them spaced correctly and tight.
/ Just ordered chains....man are they heavy #39
OK, I broke down and installed my chains this morning, ok today as I had to finish up after lunch. :laughing:
/ Just ordered chains....man are they heavy #40
Just ordered front and rear chains for my DK45. Got the 2 link ladder chains so as not to hurt concrete/asphalt. Got them from tirechains.com..... 6 packages weighing in at 330#. YEIKS. My back already hurts and i haven't even received them yet. I'm going to have to trick...er ask ... a neighbor to come and help... er ... come and look at something in my shop.
I drove tractor-trailer for years and had to carry a full set of chains in most states, primarily California. Try putting on steer axle chains, two sets of drive axle double (covers both tires) chains, and two sets of trailer chains in the blowing snow at Truckee, California, drive the 40 miles then have to take them off! Your are right chains are heavy.
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
5 SHANK V-RIPPER, 3PT (A64277)
5 SHANK V-RIPPER...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
