Just learned something new!
/ Just learned something new! #31
Some buds and I would 'find' ammo we didn't have to account for while doing guard duty in Europe. Those 5.56 would slip right through 5-6 sand bags and leave a nice 5.56 hole in the wood behind them. The wood was part of some bunkers in a hillside, so not too sure how far they went into that.
I like the idea of using burglars and other volunteers for backstops. Don't have to worry about innocent people, (humans), getting hurt.
I liked the wording.
/ Just learned something new! #32
Good info BCP, thanks. Could you use pea gravel and roofing tar as a substitute?
/ Just learned something new! #33
I would think roofing tar would work just as well as asphalt as they are very similar. Just need a plastic binder to hold the rocks together. I wonder if you need crushed aggregate or round pea gravel.
That mix could be repaired easily with a weed burner also, just lay flat and heat to remelt the tar.
/ Just learned something new! #34
I do know that a 50 cal black powder round will go through a 5 gal bucket of frozen roofing tar. It couldn't quite exit; it left a round dent on the farside.
/ Just learned something new! #35
The gravel does all the work. The tar/asphalt holds it in place.
I would rather use loose gravel in a container for a target shooting backstop. You hope to have all your shots concentrated in a very small area. The tar mix won't refill the cavities your bullets will make. Loose gravel will.
Bruce
/ Just learned something new! #36
I've always found that 3/8 steel plate mounted at about 30degree would deflect the bullets down into a nice sand box. Most potent that I tried (in basement) was 30-06 at 30', no problems as long as I had good ear protection.
/ Just learned something new! #37
We did this but at a 45 degree angle and a quarter inch plate.
/ Just learned something new! #38
i don't trust it.. I have a shooting target with swinging target plates along the bar.. you shoot them and they spin. It's IMHO.. for sub caliber or pistol.. but we had it out a while back. at 40yds I hit one of the spinner plates with my 30-06 180gr .. plates are 1/2" plate steel.
it went about 7/16 the waythru, left a thin membrane bubble on the back side
I stopped shooting it with a rifle at that point.. :)
2017 Ford F-150 Ext. Cab Pickup Truck (A59230)
2017 Ford F-150...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2006 TAKEUCHI TB135 EXCAVATOR (A62129)
2006 TAKEUCHI...
2021 Nissan Versa Sedan (A59231)
2021 Nissan Versa...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
