Just got my b3030
   / Just got my b3030
Yea full speed in m seems best
   / Just got my b3030
Thinking of 5 ft box blade from tractor supply or should I go 6
   / Just got my b3030 #13
My five foot landscape rake is wider than the wheel path and seems perfect for the b2620. But I don't know your width.
Warning: You get one too wide and the job will get done too quick, forcing you off the tractor
   / Just got my b3030 #14
Stick with 5'. You will have a hard time pulling it full. Or go with a grademaster type blade in the 6' size. Runs a little more but so much faster to use than a box blade. I have both but really don't see much use for the box blade anymore. Your mileage may vary.
   / Just got my b3030 #15
Man this thing is nice anyoneknow what range, speed if best for cutting grass
Generally Mid-range is the best for cutting grass. If you are only trimming a few inches off the top just push the pedal to the floor. If you are trying to cut knee high grass you better slow down to a crawl and even put into Low.
   / Just got my b3030 #16
Thats what I've got on the back of mine and it works great. I've also got the 2.5" wheel spacers and the 5' box blade is still a little wider.
   / Just got my b3030
Thanks 5 ft it is now.I just gotta learn to use it lol
   / Just got my b3030 #18
Congrats, the 3030 is a nice size tractor. I use to cut my grass in M on the B3200TLB I once owned, If grass is real high or land is rough try L, you can always change.
DevilDog
   / Just got my b3030
Is it normal for the hoses and cylinders to got so hot u can barely touch after using backhoe for a hour or so?
   / Just got my b3030 #20
Is it normal for the hoses and cylinders to got so hot u can barely touch after using backhoe for a hour or so?[/QUOTE
I asked the same question, and my dealer told be that its normal for the hydraulic oil temp to run 230deg. Sound too hot, but if they say its OK then I guess we'll see what happens.
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2012 Chevrolet Equinox 1LT SUV (A50324)
2012 Chevrolet...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
2003 Mercedes-Benz SLK Coupe (A50324)
2003 Mercedes-Benz...
