Just got my b3030
   / Just got my b3030
Yea full speed in m seems best
   / Just got my b3030
Thinking of 5 ft box blade from tractor supply or should I go 6
   / Just got my b3030 #13
My five foot landscape rake is wider than the wheel path and seems perfect for the b2620. But I don't know your width.
Warning: You get one too wide and the job will get done too quick, forcing you off the tractor
   / Just got my b3030 #14
Stick with 5'. You will have a hard time pulling it full. Or go with a grademaster type blade in the 6' size. Runs a little more but so much faster to use than a box blade. I have both but really don't see much use for the box blade anymore. Your mileage may vary.
   / Just got my b3030 #15
Man this thing is nice anyoneknow what range, speed if best for cutting grass
Generally Mid-range is the best for cutting grass. If you are only trimming a few inches off the top just push the pedal to the floor. If you are trying to cut knee high grass you better slow down to a crawl and even put into Low.
   / Just got my b3030 #16
Thats what I've got on the back of mine and it works great. I've also got the 2.5" wheel spacers and the 5' box blade is still a little wider.
   / Just got my b3030
Thanks 5 ft it is now.I just gotta learn to use it lol
   / Just got my b3030 #18
Congrats, the 3030 is a nice size tractor. I use to cut my grass in M on the B3200TLB I once owned, If grass is real high or land is rough try L, you can always change.
DevilDog
   / Just got my b3030
Is it normal for the hoses and cylinders to got so hot u can barely touch after using backhoe for a hour or so?
   / Just got my b3030 #20
Is it normal for the hoses and cylinders to got so hot u can barely touch after using backhoe for a hour or so?[/QUOTE
I asked the same question, and my dealer told be that its normal for the hydraulic oil temp to run 230deg. Sound too hot, but if they say its OK then I guess we'll see what happens.
(11) 8' Treated Posts (A50515)
(11) 8' Treated...
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2013 Chevrolet...
2012 JOHN DEERE 850K WT CRAWLER DOZER (A51242)
2012 JOHN DEERE...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
