Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,711
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
3 years ago I bought a used Kubota M5640 with 700 hrs on it. Since then I have added another 450 hrs. It has a L1002 Loader, a (WR Long ?) 3rd function valve, and a single Rear Remote. All part of the original package according to the seller. I am planning on adding some hydraulics and was out tracing the hoses to see what what was what. In the process I discovered the PO and PB hoses are reversed on the hydraulic block. Brings lots of questions to my mind to say the least. But I have had no problems at all. I need some input or advise from someone with more knowledge than me.
This is the way it is plumbed following the fluid flow path. Pump Out from the block goes to the Out port on the 3rd function valve. Power In on 3rd func goes to Loader valve Power Beyond. Power In on Loader valve goes back to the Power Beyond on the hydraulic block. So the flow thru the valves is reversed from what it should be. The Tank port on the Loader valve is OK. Is this plumbing OK ?? If not why is all good after over 1000 hrs. Should I switch the block lines. Has any unseen damage occurred ?? Thanks.
gg
gg
