Just can't get a good basic truck, like the old days!
   / Just can't get a good basic truck, like the old days! #381
Went to the Great State Fair of Texas on Friday. As I looked at the autos on display I kept thinking that every one of them is a luxury vehicle compared to the ones from the 70s and 80s. Some time in the 90s things started to change. The engines became more reliable and more efficient. Lots of things got way better. Then suddenly the automakers figured out how much they could make loading up everything with tech that not everyone wants or needs... but it's cool. I remember when backup cameras were not common. Then GPS and NAV systems. Some of us don't want or need all that fancy stuff, and there in lies the problem. Even the lower end Ford STX package is loaded up with things I don't want. This adds $10k to what used to be a basic truck 10 to 15 years ago. Add in inflation and my truck new now sits in the $50k range. The MSRP was $36k in 2013. That included a tow package and 4x4 with an elocker. I paid $10k less on a sale the dealer was having. I could see that truck costing $10k more than it did in 2013, but not $20k plus. I admit I have not speced out an xl usingtheir F150 build tool. When I did that on the Ranger not everything I wanted was available on the low end package. I had to upgrade to get the bigger engine, which put it close to F150 prices.
   / Just can't get a good basic truck, like the old days! #382
It will take a Lot to convince me that the new RAM I6 Aluminum sleeveless "plasma transfer wire arc (PTWA)" coating on the cylinder bores is better longevity wise than the Iron AMC 6, that Chrysler used for decades in the Jeeps.
I just had the granddaughters Wrangler 4.0 apart due to a bad exhaust valve, and checking the bores at over 230K miles there was no cylinder ridge at all, all cylinders 155+ after recutting the seat and a new valve installed.
I would like to see rebuild cost comparison as well. If any debris ever scores a cylinder wall, they are going to make like a Chevy Vega aluminum 4 did back in the day. Some reports of overheating and of all the things you don't want on an aluminum block liner less engine are bad thermostats which apparently were installed on some engines. No arguments it is a powerhouse though.
No accident, that "cast-iron reliability" predates all of us..... most today can't be bothered to season them, but nobody ever wore-out a cast-iron frying pan.
High-Specific Output.... sells well @ dealer-demos; if it only makes it 10% past the warranty period, Meh.
Transmissions too..... don't know what Rolls and Bentley are using today, but I doubt they are GM units, as one or both of those OEMs used long ago.
IIRC, those new RAM pu's with the 6, are rated lower Towing capacity, than what many modern 1/2 tons got to in recent years. If I'm right ^, reflecting more Go Fast Truck (with all that power) than Work Truck focus. Marketing-wise ^, not a bad play, given how many personal trucks are (close to) empty-load much of their lives.
Rgds, D.
   / Just can't get a good basic truck, like the old days! #383
I raised the point in some of the EV threads on here, that they are being marketed pretty much like cell-phones.
The parallel is a little more blatant in the EV case, but, the points you raise ^ make a good case for saying modern vehicles are pretty much in the same situation. Most manufacturers warranties on electrical/electronics in vehicles are not long..... who is going to pay for advanced-diagnostics @ 8+ years out, or pay to have a soy-based chassis wiring harness replaced ?
I guess I need a Model A pu ?
Rgds, D.
   / Just can't get a good basic truck, like the old days! #384
This seems fitting for this tread I stumbled on despite not being a pickup truck. https://carbuzz.com/chevrolet-express-van-refuses-to-die/
Great point. I haven't crawled under one lately, but @ 10K# towing, I expect there is still a full-frame under there.
My HVAC contractor neighbour had a GM cube-van for a long time, put well over 600k km on it. Other than tires, brakes, tune-up items, and a coil-pack or 2, it basically needed nothing. He said he had 2nd thoughts, driving it to the Auction for the last time.... "even the AC still worked".
Rgds, D.
   / Just can't get a good basic truck, like the old days! #385
Rgds, D.
I'm sure there is a frame under there I really like the simplicity and durability of my 2018 Chevy 4500 Cutaway chassis to my surprise it doesn't use rectangular or square steel tubing
ust simple problaby less ridgid but beefy channel for frame rails. Since owning and dealing with rust perforation on boxed frame Tacomas for almost 20 yrs I was relieved to see open channel Frame rails on my 4500 instead. Wish I could praise what's on that frame behind the cab lol. similarly Chevy by still producing those vans and cutaways using older tried and true auto engineering and oldskool tech got that one right for sure.
   / Just can't get a good basic truck, like the old days! #386
Rgds, D.
Get two… a pickup and 1.5 ton stake bed.
A friend owned a floor covering business and his logo had his 1931 AA Ford stake bed which he used for the business…
The Dodge Ram Maxivan could haul 1 roll of carpet.
The AA could haul many!
   / Just can't get a good basic truck, like the old days! #387
Rgds, D.
Just my EV data point -just past 2 1/2 years on the Model Y and so far it has needed washer fluid . Nothing else.
Tesla also has just increased the longevity of parts of electric drivetrain coverage on some of the newest just released models. I have no plans to ever replace the 03 RAM with Cummins power and a manual transmission with a new truck. I really dislike what GM and Ford have done with the new automatic trans valve bodies.. nothing like locking up a driveline at 70 MPH for fun.
   / Just can't get a good basic truck, like the old days! #389
Yep, closed channel in flood-the-roads-with-salt country often doesn't end well.
Open-channel can be plenty strong.... thinking of video I've seen of a triple-frame Autocar, but that's a bit heavier than most of us need....
Rgds, D.
   / Just can't get a good basic truck, like the old days! #390
Two… a pickup and 1.5 ton stake bed.
Progress ?
:cool:
Rgds, D.
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2016Takeuchi TL8 (A47477)
2016Takeuchi TL8...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56129)
2020 FREIGHTLINER...
