Just bought a boom pole
   / Just bought a boom pole #31
Bob in Va or others, how did you attach your boom pole in your FEL bucket? I don't have a welder but had thought of straps, chains and binders. Later this summer I hope to start work on a pole barn and was considering lifting the trusses in place with the loader bucket and boom pole.
I started one yesterday. I'll try to get pictures.. I'm using square tubing (and other stuff that's laying around. Am planning on switchable attachments on the end like a moss rake, etc..
I've not yet figured out how to put a chainsaw on it.. :)
   / Just bought a boom pole #32
The boom pole is well made, and I was thinking of modifying the end piece with some hitch type tubing. I want to mount a hydraulic chain saw on the end.
As far as the beard, that was my Christmas look until a couple of weeks ago. until I trimmed it back some.
I like how you put the brace on it, do you know how much weight it will lift.
That would be a good ideal with the chain saw,i would like to see pictures of it one day.
Did you see the video of the guy that put a chain saw on the end of a ladder.:D
   / Just bought a boom pole #33
It will lift a 450 lb welder/generator at the second hook.
Yes, I did see that post about the ladder and chainsaw. Good old redneck ingenuity.
   / Just bought a boom pole #35
I agree with Diamondpilot, its probably on my bottom of the list to, but they are handy for putting up trusses, and maybe lifted something in the bed of a truck so you don't have to get so close with the tractor. I didn't have one and was needing one for the next build.
Thanks for the advice.
I guess I was not very clear. I have a 3 point boom pole that I have used 1 time in 5 years. Its at the bottom of my use list. Now my boom pole that I built for my FEL I use all the time. I gets used probably every other week. It is very strong and will easily lift my 5' Ford Bush Hog that is built like a tank.
I do see some flexing on it but it has never bent. I was planning on adding some top bracing but just never go around to in and got put on the back burner after I used it with no issues. I do agree the top bracing is a good idea though.
Chris
   / Just bought a boom pole #36
I use mine to pull my water pump out of the well. I attach a pulley to the end and run the rope from the pump through it. I then attach the rope to my truck and pull until the pump comes up, 300'.
Solo
   / Just bought a boom pole #37
I had brackets welded on the lower part of my 3 pt boom pole and bolted on a ramsey badger electric winch (2500 lb) and remote selenoid switch. It's on the back of a IH 140 tractor. The cable is strung through a pulley at the top of the pole. I've lifted (winched) 650lbs. Beyond that the front wheels start comming up. It increases the vertical lift range (like from pickup bed to the ground and from trailer bed up and over side rails) and simplifies skidding logs. I don't have a loader.
I want to change to a hydraulic winch that works off remotes. The electric really sucks the amps (100 amps) and gives my alternator a real load. It works good and I've used it alot. If interested I could post a pic.
   / Just bought a boom pole #38
I
Hm, what kind of question is that?:D We all love pictures, the more the merrier. Please post them.
JC,
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2014 VOLVO TRUCK VN SERIES (A50854)
2014 VOLVO TRUCK...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
