Just another junk chainsaw
/ Just another junk chainsaw
Stihl dealer estimate was $700 to fix and had 2 weeks, another dealer had it for a month. He finally picked up his saw and drove 50mins to me one way to get ut looked at. Had it a hour tore down figured out why it burned up. Gave options on repair, Redneck it, aftermarket, oem. Redneck repaired for a total of $200. $100 was for new parts.
20 mins of test cutting today so far. :bananawiggle:
As delivered
/ Just another junk chainsaw #162
Good job!
Wood ash, 14.5" across x 12.5" deep. same square chain and 3/8 7T ran on both. Both were running fat at 12K due to breaking in with new rings and rebuilds.
046 has wide open dual port muffler with enlarged side exit too. D shaped combustion chamber.
475 stock muffler, no spark screen.
I always considered this 475 a good runner, so that is saying something when this 046 on it;s 1st tank was that much stronger.
The 046 was noticeably stronger in the cuts.
046 9.32 9.52
475 10.91 10.87
/ Just another junk chainsaw #164
Been awhile since I chimed in on this thread.
So as the "theme" goes, I was was using one of my junk ebay purchases of $150 to cut up a ash tree today and took some times.
The saw is one of my stock 116si's. Man I love these saws.
Its wearing 3/8" full chisel, rakers set at ~.045, and 16" bar. And had cut about a cord prior to these times. (notice the brown on the top of the teeth).
Anyway, I was getting ready to buck it up as the wife got off work, so I had her take some times for me. Tree is ~15" tapering ~13"
From right to left, 5 cuts
10.91, 11.03, 10.16, 10.03, 9.78
Those 45 rakers look nothing like the 40-45 test chain I did once. They look about like these at 30. But again it is just a pic, but dont look like much has come of those rakers to make them 45. :confused:
I did this a few days ago with a 49cc.
Out of curiosity. I just took the very aggressive 3/8 square chain with lowered rakers that I ran on the DP muffler 440 046 both stock, poulan 445 475, husky 372. I put the 3/8 72dl chain 7T on my ported redmax 5000 that was built for cutting pulp wood and higher rpm use up to 16.8k IF cookie cutting. I have been running it a super fat 13.8k for years now even at gtg's. Not seeing much use in my stable with maybe 5 tanks or so and owner before me put 150 tanks through it in 3 weeks use.
Anyhow cutting the same ash log 14" wide, 13" deep I have been testing the above saws in. The ported redmax 5000 was right there with them in the mid to high 10's.
Just some more junk chainsaws showed up to fix yesterday. 394xp and a ported 371xp
3 more junkers coming in if anyone is looking for, Stihl 084 with 30" I think and a like new husky 350 and a like new looking stihl 031. All running and ready to cut. I just dont need to keep them around.
Pics in a few...
371 was a battle but finally figured it out on the no start issue. :cool2:
/ Just another junk chainsaw #169
You need to get some older dolmars in.:thumbsup:
2 166 were sold in Bucyrus. I just wasnt interested in them after owning several of them. Friend bought them both and flipped one on feebay.
350
031
084
/ Just another junk chainsaw #174
Those are a little bigger (and usually lotos more $$$) than I would want.
I have a soft spot for 3 saws, 115i/540, 116si/6000i, and 120si/6800i.
I jump on any chance I get for a runner 116 or 120 for $200, and the 115's usually around 150, but have went a tad higher for super good looking ones.
Here lately though, the 116/120's seem to be bringing upwards of 300 on ebay. But a year or two ago, I was buying quite a few good runners under $200. Just never seem to find them locally :mur:
Fixed that last post for ya LD1. :thumbsup:
/ Just another junk chainsaw #177
Did you ever get that video I sent you??
/ Just another junk chainsaw #178
Hey XYZ123 off the top of your head where is the oil rate adjuster on the Dolmar 6400? The saw is using more oil than gas per tank full. I want to dial it down a bit.
Didnt work and 160mb :eek:
TM
Oiler on 6400. I'm NOT thinking straight right now. Hint hint. Look on crankcase on bottom right where the clutch area is.
/ Just another junk chainsaw #180
ITs on the bottom. Same place as every other saw I have seen. (which is mostly dolmars:D) Only difference is on the 6400/7300/7900 is the oiler is only 1/4 turn adjustment from wide open to minimum. So dont back it down too much:thumbsup:
CASE 586H ROUGH TERRAIN FORKLIFT (A64279)
CASE 586H ROUGH...
2013 EZ-GO GAS GOLF CART (A64280)
2013 EZ-GO GAS...
1978 Wilson AGH-500 (A64119)
1978 Wilson...
F-150 4WD (A63689)
F-150 4WD (A63689)
2014 Nissan Murano Cross Cabriolet AWD SUV (A61574)
2014 Nissan Murano...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
