Joy Stick from ebay
/ Joy Stick from ebay #1
yooperterry
SAult Ste Marie Mi
John Deere 2025R
So I purchased a 2no joy stick switch to build a control for my frontier SB1154 shute. However the switch does not have a diagram for the elec. connections?? There are 4 screws for connecting the power and control for the direction you'd want the shute to move. But if I were to connect a + & - that only leaves 2 connector screws for power out? Anyone know how these things are wired for this type of control?? Thanks
/ Joy Stick from ebay #2
I'm guessing youre planning to use a linear actuator for movement? The actuator only has 2 wires? A momentary double pole, double throw switch would work.
/ Joy Stick from ebay #3
Typical of how to wire 2 axis NO joystick... IF you need to change directional control (up/down) to coordinate with Acton of a linear device reverse the polarity of DC voltage supply...
2012 FREIGHTLINER M2 6X4 T/A GARBAGE TRUCK (A66091)
2012 FREIGHTLINER...
(UNUSED) REDDICK OFFSET DITCHER, 3PT (A64278)
(UNUSED) REDDICK...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
Landhonor Hydraulic Logging Winch (A66285)
Landhonor...
John Deere 825 6R Cultivator (A66408)
John Deere 825 6R...
2008 12ft. Alumacraft Flat Bottom Mud Boat (A64194)
2008 12ft...
