Joining the Pack!
/ Joining the Pack! #1
rvaitor
Platinum Member
Nashville, TN / Hickory, NC
Kioti DK55C
Looks like I'm joining the pack. I've made a deal on a DK55C. I currently have a Mahindra 6000 4WD FEL which I am very happy with, but will be selling.
The opportunity and the fact that the closest dealer to our property is a Massey / Kioti dealer were factors. I am still doing some field reclaimation and clearing so am concerned about the Cab getting banged up, but am looking forward to the creature comforts associated with it.
I am interested in hearing from anyone with a Kioti Cab unit and their experiences. Will be pulling a 7ft International Machines mower, 7ft box Blade. Have R4 tires. Would like a root grapple, or tooth bar set-up, top-n-tilt unit for the box blade, but need to sell the other tractor first.
/ Joining the Pack! #2
Welcome to the pack. I have the much smaller CK30hst and it's done what I have asked of it. No cab, so I can't help you there. I'm sure some of the members have your setup and can comment. Enjoy the new toy. /forums/images/graemlins/grin.gif
/ Joining the Pack! #3
Congratulations on your new purchase. I'm not a 55 owner, but a daedong is a daedong, and I think you'll be happy with Kioti.
John
/ Joining the Pack! #4
<font color="orange">Welcome to the Pack !</font>
I have a CK20 with the Sims cab that is no factory cab, but it is still a cab and makes a world of difference on a tractor.
Good luck with the sale.
/ Joining the Pack! #5
Congratulations on your 55.
I have the 45 with cab, I think basically the same tractor except the turbocharged engine on the 55. No opinions yet as I only have 22 hrs on mine but the fact that you are inside out of the dust when plowing or doing any field work is a plus, I've only had the AC on low so far and it cools very well.
What I have found is the FEL is a pain in the butt to take off, will write more about that later after I attempt to get it back on. Good Luck with your new tractor.
/ Joining the Pack! #6
Ihave a new dk55c and I love it so far. I bought the quick attach forks and they are the best thing I got extra. I noticed a bit of noise in the hydraulics but it may be normal for these I have been told. I love the air conditioning here in Texas. I pulled an 8 foot offset disk in my pasture I reclaimed and it did very well. I have the Kioti 1595s loader and I have no complaints with it. Love the self leveling feature. I did deflate the r-4 tires a lot in order to keep my teeth in my head. When I got it they were at 30 psi. !2 is a lot softer ride.( the rears only). I hope it is as great a tractor as I think it will be. At 54 I don't want to buy another if I can help it.
rick roberts
/ Joining the Pack! #7
</font><font color="blue" class="small">( I did deflate the r-4 tires a lot in order to keep my teeth in my head. When I got it they were at 30 psi. !2 is a lot softer ride.( the rears only) )</font>
Most industrial tires are bias ply tires, and do not handle low air pressures well compared to radial tires. The sidewalls can't stand the bulging that radials enjoy.
Running lower pressures in bias ply tires, especially without carefully determining weight loads to inflation can easily ruin the sidewalls of bias ply tires.
If you see ANY bulging of the bias ply tires while under a heavy load, you're probably limiting the life of the tire a great deal. Complete sidewall failure is not uncommon in underinflated bias ply tires.
If you regularly use heavy attachments, such as a backhoe, with 12 psi, you may be ruining your tires. There is a good bit involved in derterming weight per cubic inch, weighing axles acurately etc. are needed.
It's pretty much never necessary to run at max inflation as stated on the sidewall, but I also wouldn't run it at less that 20% of that maximum, avoiding any bulging of the sidewalls of bias ply tires.
You can get a pretty good ride at 24psi if the max is 30, and not do damage to the tire. Even 20 would be WAY better than 12psi.
Do a google search on radials vs bias tires to find out more about determining proper inflation.
John
/ Joining the Pack!
Thanks to all that have responded.
I am getting a Rhino loader - does have the quick attach with pallet fork attachment.
Also, not sure I understand how the two sets of remotes work or what the benefit is. One set has 'float' and the other detent only??? I'm getting a 7ft box blade. And the rear electric plug - what is that for?
Also, what is the history of Daedong? Do they make tractors/engines for others as well?
/ Joining the Pack! #9
Thanks for the information- I will pump them up a bit. I have a smaller ( ie.narrower) sized rear r-4 on my 410 JD backhoe which weighs 14K+, and I do watch the sidewalls. This new Kioti is less than half the weight of the hoe and even at 12psi there wasn't any bulge in the sides. I just felt like I was riding a golf ball at 30 psi with all the bounce, and no implements except the loader in front.
Now if I could get the air down in that dozer track??
rick roberts
/ Joining the Pack! #10
</font><font color="blue" class="small">( I just felt like I was riding a golf ball at 30 psi with all the bounce, and no implements except the loader in front. )</font>
I understand that totally. The problem comes while you're bouncing with low inflation and flexing those tires. You probably wouldn't notice it from the operator's seat.
20psi will give you a much better ride, and give you a little more traction.
John
/ Joining the Pack! #11
<font color="blue">I am interested in hearing from anyone with a Kioti Cab unit and their experiences. Will be pulling a 7ft International Machines mower, 7ft box Blade. Have R4 tires. Would like a root grapple, or tooth bar set-up, top-n-tilt unit for the box blade, but need to sell the other tractor first.
</font>
I have ~560 hrs on my DK55C, bought new in July '04. I could not be happier with the tractor or its' capabilities. I have used it to restore a circa 1740 farming operation: restored 10 acres of fields, rebuilt over 2k feet of stone walls (i STRONGLY recommend a grapple; i recently purchased a unit from Loflin Manufacturing and i'm very pleased with the performance). I've done more with this machine than i could have imagined..
Don't worry about the cab. I also use mine for logging. I've used it extensively in the woods of New Hampshire (50+ cords of woods) on a variety of trails (read that: some barely wide enough for the tractor).
Couple of things about the cab:
- the A/C unit is STRONG. you could hang meat inside without spoilage. the unfortunate side effect of running the compressor in such a small area is how dry the air gets inside the cab (helpful that there are 2 cup holders). you will get cotton-mouth!
- if you're logging, purchase the grill guard and don't forget to turn your mirrors in when you're on tight trails in the woods (helps to prevent limb snagging).
- visibility with the cab is less than ideal - you'll get used to it.
i would have to say that this machine has exceeded all expectations. the biggest concern i had prior to the purchase was reliability - definitely not a problem with the amount of hours i have on this machine.
good luck
pf
/ Joining the Pack! #12
<font color="blue">Also, not sure I understand how the two sets of remotes work or what the benefit is. One set has 'float' and the other detent only??? I'm getting a 7ft box blade. And the rear electric plug - what is that for?</font>
the remotes (assuming you're talking about the ones in the rear) are for implements that use hydraulics (e.g., backhoe, etc). i strongly suggest getting 2 sets of rear remotes when you purchase the tractor. you'll always find a use for them.
the rear electric plug can be used to hookup trailer lights - frankly, i'm using mine to run the blender /forums/images/graemlins/wink.gif
/ Joining the Pack!
good luck
pf
Thanks
)</font>
Could you tell me more about the grapple and how you have it hooked up and controlled? I do have what I think are the standard two sets of remotes in the rear. One is listed as having the "float" function and the other only "detent". I think I want to get a grill guard anyway - just not sure how or if there is a problem mounting with the Rhino loader.I'm 6'2" so visability issue may be even worse. I'm glad to hear about the reliability - There is a lot of standard equipment on these machines - I don't know what else I need - I would like more info on your grapple set-up cost and how you use it.
/ Joining the Pack! #14
<font color="blue">Could you tell me more about the grapple and how you have it hooked up and controlled?</font>
the loflin root grapple (~$4,000 installed) is a quick attach implement that is plumbed into the rear remote. the FEL hydraulics allow you to raise/lower/rollback. to open/close the grapple, i operate the port controls (A/B/C/D depending on which remotes your're using). a few pics are worth a thousand words, so i'll post the pics i have ASAP.
this is NOT an ideal setup. i have seen other setups that attach a switch to a FEL control that allows you to open/close the grapple; this would make it much easier to use.
i've used the grapple for:
- moving logs/cordwood
- moving rocks
- ripping roots out of a field (i recently reclaimed a 4a field); the grapple was perfect for removing the layer of peat/roots that the disc ripped up.
i'm constanly finding more uses for the grapple, and consider it to be one of the most useful restoration tools i have (althought the BH is a close second).
i'll post a pic of the grapple shortly.. i'm up to my rear end in planting @ the moment.
pf
/ Joining the Pack! #15
I've got a dk55c with a grapple. Mine has a button on top of the fel stick. It controls a valve that redirects hydraulics to open/close the grapple. It works very well. I've got a WR Long grapple - I'd recommend getting a strong one - mine is a bit bent but has taken a real beating.
As for the cab, I've busted off the antenna round about the first week or two. I'd also get a grill guard. I've smashed in my grill and broke the headlight. I've tried to buy one twice, but the dealers never had one and I never managed to get one ordered... you better if you get a grapple or do much bucket work.
The cab is nice and I'm your height, so visibility is okay. I have four rugrats, so I'm really paranoid there - especially since the hearing is limited with a cab and the radio going...
Enjoy!
/ Joining the Pack!
Got my first look today.
Here is a link to some pics DK55C Loaded
Looking forward to some seat time.
Thanks for all the advice.
There is also a link to some AGCO and Deere Eqmt(in transit the same day as the Kioti)
2011 Bobcat T190 Compact Track Loader Skid Steer (A66734)
2011 Bobcat T190...
2003 Toro Workman 2110 Gas Utility Cart (A66734)
2003 Toro Workman...
GENERAC MOBILE  MTL65 LIGHT PLANT (INOPERABLE) (A68842)
GENERAC MOBILE...
Superior Trailer Product 15 Ton Yard Truck Ramp (A66736)
Superior Trailer...
1997 KENWORTH T300 4X2 S/A CAB & CHASSIS TRUCK (A69167)
1997 KENWORTH T300...
2025 CATERPILLAR 285 SKID STEER (A65056)
2025 CATERPILLAR...
